porting FAST intake and milled ETP heads
Old Jul 1, 2006 | 08:48 PM
Tom@SpeedInc's Avatar
Default porting FAST intake and milled ETP heads
So I have my Iron block 402 ready to go (eagle crank, compstar rods, diamond -14cc) and ETP 245cc heads back from the machine shop, 64cc heads milled off .050" mathmatically produces 55cc, using cometic .040" head gaskets, looking about 11.5 area compression. INTMD8 from speed inc. specing a cam. Everything is ready to go, the machine shop was going to port the fast intake for me after I put the heads on the motor. Really I'd like to get the motor together next weekend.
What is everyones opinions on running an unported FAST 90 intake with ETP heads? Probley this winter i'd take the manifold off for porting or replace w/ sheetmetal and or harrop.
I've had .050" milled off the heads, could I run into some difficulty fitting the FAST intake as it is? I intend on grinding the tabs down (i've used the search button a few times)
With ETP heads which pushrods has everyone gone with? I have a set of 8.050 and 8.100 pushrods, will check length when cam goes in.
thanks
Old Jul 2, 2006 | 03:52 PM
TTT, nobody runs etp heads?
Old Jul 2, 2006 | 07:18 PM
gtodoug's Avatar
I used 8.125" rods with my ETP 245's with my 408 in my goat. As far as the porting goes, my heads are milled to 61cc and I had no problem with my Mamo ported FAST intake bolting right up. I checked it while It was still in pieces and it couldn't have fit better. Another 6cc smaller chamber shouldn't make such a big difference. However, keep in mind there isn't much material at the top/bottom of the intake runners on the fast so be careful how much you take off.
dougie
Old Jul 2, 2006 | 08:14 PM
Patrick G's Avatar
LS1 Tech Administrator
A stock unported FAST is better than an improperly ported FAST. Yes, it is possible to mess up and make it worse. Best bet is to have an expert do it or have them walk you through the do's and don'ts.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jul 2, 2006 | 08:38 PM
thanks guys, think i'm gonna order up couple sets of pushrods (8.075 8.100 8.125) Just so I don't get screwed and car wont' be ready for GTO nationals, are you going Doug?
Doug- What style of pistons do you have flat or dished? Are they ET specific pistons, judging you went with LME they are Wiesco pistons? Did you or one of your guys check PTV? was it close or have some room?
61cc 245heads? how much did they mill?
thanks!
Old Jul 3, 2006 | 10:40 AM
carado1984's Avatar
i think mikey from rapid said he would port a fast for about 150$ i could be off but talk to him
Old Jul 3, 2006 | 10:48 AM
Viper's Avatar
"Think i'm gonna order up couple sets of pushrods (8.075 8.100 8.125)"
That's like $350 in pushrods; just buy a $20 pushrod checker and do it right.
Old Jul 3, 2006 | 11:03 AM
98Z28CobraKiller's Avatar
Restricted User
I would just open it up as much as I could w/o letting light into it. Just kidding. Pay a guy that knows like Tony@AFR and you can feel warm and fuzzy when you put it on........until you brake the oil pressure sending unit and you have to take it apart again and wait a couple of days to get a new one and put it back together. Sorry, I am ranting.
Old Jul 3, 2006 | 11:11 AM
I'm going to GTO nationals 7/11, motor and heads are ready, I have one shot to order parts for this weekend.
Ordered a 236/242 .615/.612 113+5 cam on XFI lobes and my collection of pushrods
Old Jul 3, 2006 | 12:35 PM
beardWS6's Avatar
Man, I love my ET heads. My car runs strong!!Good luck with the set-up and let us know how it goes!
Old Jul 3, 2006 | 04:34 PM
xfactor_pitbulls's Avatar
Yep, I actually boogered up the first one I did for myself. After 5 or so its cake. You can easily blow through the intake if you get greedy.
Brandon
Old Jul 8, 2006 | 12:27 AM
So I found Milled 55cc ET heads and cometic .040 paper thin gaskets will not allow FAST 90 to fit. The manifold bolt holes become too narrow, I tried reaming out the bolt holes in bottom section of the FAST and sanding the tabs down- no go.
Put on a set of GM 6.0 MLS gaskets alls going smooth again, I got the bottom section of the FAST to fit.
The windage tray and oil pan on this GTO is tight, stacked 4 washers, had the slightest bit of resistance torquing down the oil pan and enough clearance for the rods. Like it was just touching the windage tray.
Old Jul 8, 2006 | 07:12 PM
Motor is back together in the car, intake WILL NOT fit, the bolt holes won't line up. I'm gonna call ET on monday, looks like i'm gonna throw on some 243 heads for the mean time.
Old Jul 8, 2006 | 08:22 PM
beardWS6's Avatar
Why will it not fit?
Old Jul 9, 2006 | 03:58 PM
The bolt hole line up for the intake manifold is about 1/16" off, the intake bolt holes are too narrow. The only thing I could do is sand the tabs off the manifold?
I don't see how grinding the tabs down is going to change the relation of bolt hole and manifold alignment on them. Cause all the manifold will do is sink lower with no tabs, it won't alter the bolt hole alignment.
The more you mill off the heads, the closer the manifold bolt holes get to the deck.
The heads were milled .050" from 64cc.
Old Jul 9, 2006 | 06:06 PM
Tony Mamo @ AFR's Avatar
Flow Wizard
Drill the intake manifold bolt holes/tubes to a larger diameter....if its close now you wont need a much larger hole than the factory (FAST) provided to be able to start all the threads and cinch the intake down. There isnt much else you would be able to do in this situation and its the easiest quickest fix for the problem you describe.
Good luck....let us know if that works assuming you give it a try.
Tony M.
PS....I would also grind a little taper in the leading edge of all the bolts to help guide them properly into the head reducing your chances of cross threading them.
Old Jul 9, 2006 | 06:19 PM
thanks Tony
I've drilled the tubes slightly (FAST manifold), i'm going to make a better attempt at it tommorow morning.
Old Jul 9, 2006 | 07:01 PM
Black02SS's Avatar
It is more then others charge, but I would have Tony port it if it was me.
Old Jul 10, 2006 | 09:03 PM
Well I kinda gave up on drilling the intake, hogging out an $800 manifold and potentially stripping the holes on some ETP heads isn't cool. Since the ETP heads outflow even the FAST intake i've talked to a few some companies about a sheetmetal intake.
Thanks to Tom at speed Inc. I have a set of Dart 225 heads on the way, for the mean time..
Old Jul 10, 2006 | 10:26 PM
pianoprodigy's Avatar
Hmmm, I hope I don't have problems with my ET 215s @ 59 ccs and my FAST 90...
