Best Cam
Old Jul 4, 2006 | 12:45 AM
ws6102488's Avatar
Default Best Cam
Looking into getting cam but wanna know some inputs on what size and best results. I have a 2000 ws6 LT's ory SLP lm built 4l60e with vig 3600 ported tb and mass air slp lid and NX wet kit 150 shot and tuned by rpm. I wanted 2 see what a good cam was for this setup and what do i need 2 buy besides a cam.
Old Jul 4, 2006 | 12:54 AM
Lithium's Avatar
SSU's Drunk Typing Whore
A 12 bolt
Old Jul 4, 2006 | 01:11 AM
ws6102488's Avatar
stuff do go with cam lifters springs etc the 10 bolt will hold
Old Jul 4, 2006 | 08:57 AM
ws6102488's Avatar
no replys come on guys
Old Jul 4, 2006 | 09:21 AM
Tan327's Avatar
Originally Posted by Lithium
A 12 bolt
Yep, go for a 12 bolt first.
Old Jul 4, 2006 | 09:24 AM
udlose99ta's Avatar
sounds like your almost ready for some injectors also, i love my MS3 cam and it will go good with you nitrous.
Old Jul 4, 2006 | 09:37 AM
Patrick G's Avatar
LS1 Tech Administrator
228/232 .588/.592 110LSA +1 ground with COMP XE-R lobes is an incredibly well rounded cam, giving tremendous mid-range punch, a strong bump in dynamic compression and solid top-end power. The key to the cam is having the proper amount of overlap (while centering it over TDC) and using an intake valve closing point that works in harmony with the LS6 or FAST intake manifold.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jul 4, 2006 | 09:54 PM
SS LS1's Avatar
Patrick,could you answer a few questions please?
What RPM would that cam peak out at?
What is the DCR with stock heads and a cam like that?
What would be a good shift point for that cam (stock rod bolts) with a 3500-3600 rpm stall and 3.23's?
Would you recommend the Comp 918 springs for a cam like that?
Thanks! Greg
Old Jul 4, 2006 | 10:45 PM
eamador11's Avatar
A 12 bolt
its fine, but in my opinion, use a torque wrench
Old Jul 5, 2006 | 08:03 AM
Patrick G's Avatar
Thanks! Greg
Engine would peak between 6200-6300rpm.
DCR with stock cam is 7.0:1, with this cam it's 7.9:1.
Shift point would be 6400-6500rpm.
918s are not recommended. Dual springs are.
__________________
Old Jul 5, 2006 | 09:08 PM
SS LS1's Avatar
The Peak Power RPM looks good and the shift point looks safe with stock rod bolts but I don't have a good feel about additional DCR yet (trying to read all of your posts to get a better feel for it).
How noticable would a .9:1 bump in DCR feel? Can you put it into perspective some how? For example a bump of 20+hp you can feel in your seat, how much seat feel would there be with a +.9:1 DCR boost? Or use any other example you can to help me put it into perspective if you can.
Also (if you don't mind) what would the DCR be for a G5X3 112 or a F14 112 on a stock LS1 compression/head motor be?
Thanks for your time in helping me get a feel of what to expect with a cam change.
Greg
Old Jul 5, 2006 | 11:23 PM
RoastEmSS's Avatar
glad to see your cammin that beautiful SS
Old Jul 5, 2006 | 11:34 PM
Lithium's Avatar
hahahaha reeeeeal cute
Old Jul 6, 2006 | 09:42 AM
HaulinHawk's Avatar
You will need a 12 bolt!!
Old Jul 6, 2006 | 10:15 AM
Patrick G's Avatar
Greg
Don't let the 7.9:1 DCR scare you. You can run 8.5:1 DCR on 91 octane. A 9 tenths increase in DCR will give you a big push of torque that you can feel SOTP. It will feel like 20 hp because it's like 20 lb ft of torque. The DCR of the G5 and F14 cams will be a little lower on stock heads because they have bigger duration and wider LSA. Don't get me wrong though...both of those are excellent cams too and would work well with stock heads.
__________________
Old Jul 6, 2006 | 01:31 PM
Blue Hawk's Avatar
The last guy who told me that came back from it's very first track pass with a nice "clunk, clunk, clunk..." coming from the rear end...
Old Jul 6, 2006 | 05:32 PM
tbick's Avatar
how easy would that 228/232 110+1 cam be to tune for an a4? it seems most people recommend cams with a lsa 114. that cam seems nice but i am worried about tuning issues.
SS LS1's Avatar
First off ws6102488 sorry for hijacking your post!! I just wanted to steal a little bit of Patrick G's attention.
Patrick, thanks for taking the time to help me better understand the DCR #'s. Up here in Michigan 93-94 octane is plentiful so no 91 for me. Unless I go back on the Power Tour and travel through some of those 91 octane only states.
Old Jul 6, 2006 | 05:38 PM
Patrick G's Avatar
That's why my cam gives DCR of 8.73:1. I live in the land of 93 octane. Believe it or not, but my cranking compression is 250psi.
__________________
