Can you run the LS6 intake with the LS1 coolant crossover pipe
How did anyone make out installing a LS1 coolant line setup under a FAST 92? I already installed mine with block-offs in the rear but I'm willing to redo it if there's a way to NOT block off the rears.
You can run the coolant pipes with the LS6, multiple guys on here have used a chisel or a grinder and grinded the ribs off and worked fine.. guys on YouTube have done it as well
I will be doing the same on my LS6 intake soon the chisel way...
I have a photo as well of where to shave the ribs. I will post later
