Angle milling ET heads to 12 degrees?
Old Jul 6, 2006 | 06:57 AM
Fireball's Avatar
Default Angle milling ET heads to 12 degrees?
Has anyone done this? Rules for a class I'm interested in allow angle milling, but require valve angles of +/- 3* of factory. This would mean ETPs have to be changed to 12* to be legal...
Old Jul 6, 2006 | 07:24 AM
slow trap's Avatar
i don't see why that would pose a problem,your headers should still clear easily and the slight diference in the angle shouldn't hurt the way the intake bolts up either.i wouldn't thing a 1/2 * in geometry should hurt that much.does people in that class actually get tore down and checked ? i can see why someone with a 23 *sbc verses an 18 or 15* sbc would be handicapped but i was just wondering if other racers protested or what.
Old Jul 6, 2006 | 07:43 AM
Fireball's Avatar
Since between the purse and contingency the potential proceeds to the winner can exceed 2000.00, I'd imagine protests are possible.
Old Jul 6, 2006 | 09:08 AM
Tony Mamo @ AFR's Avatar
Flow Wizard
It probably could be done by a good machinist (correcting the intake flange might be tricky, but do-able). It will take about a zero-.150 angle mill with the material obviously coming off the quench side of the chamber, not the sparkplug side which is obviously more common. You may even need less if the heads are really closer to 11.3 degrees etc., etc. I would check with the guys at ET and see the exact angle the heads are currently configured for (or simply measure with quality instruments).
Good luck....sounds like an interesting project.
Tony
Old Jul 6, 2006 | 04:44 PM
Brian Tooley Racing's Avatar
Or you could angle mill a TFS 13.5 degree head to 12
Old Jul 7, 2006 | 12:03 AM
Cary@Perf-Induction's Avatar
Collections Hold
Default 11.3????
Tony
11.3?? is that from your CMM??
Old Jul 7, 2006 | 05:20 AM
Fireball's Avatar
I think that was a general statement
Old Jul 7, 2006 | 11:04 AM
JL ws-6's Avatar
Race your car!
I think you'd be way better off angle cuttin the et's to 12 then messing with with trick flow stuff. IMO.
