Calculating Compression
Old Jul 7, 2006 | 01:55 PM
seth webster's Avatar
Default Calculating Compression
Can anybody help me calculate my compression??
I will be running a 347 cubic inch LS1 block with Mahle 4cc valve relief pistons, TSP's LS6 heads(62cc) with .040 cometic gaskets, and the T2 TSP 232/234 .595/.598 112 cam
Thanks in advance
Seth
Old Jul 7, 2006 | 02:37 PM
Beast96Z's Avatar
SCR will be 10:8:1 with around 8:2:1 DCR depending on advance. I figured using +2.
Old Jul 7, 2006 | 03:24 PM
Hey i apreciate that
Old Jul 7, 2006 | 04:12 PM
Q8CamaRo's Avatar
Old Jul 7, 2006 | 05:57 PM
Beast96Z's Avatar
Originally Posted by Q8CamaRo
10.4:1
Wrong
Old Jul 7, 2006 | 07:04 PM
Q8CamaRo's Avatar
Wrong
Really!
i just used the calculator from
http://www.c5frc.com/calculators/Com...Calculator.htm
Old Jul 7, 2006 | 09:14 PM
Viper's Avatar
Try this one:
http://users3.ev1.net/~black_ops/cam...calculator.xls
Uses the cam info; yours did not
Old Jul 7, 2006 | 09:32 PM
Beast96Z's Avatar
Really!
That calculator does not go "above deck" on the piston height. If you enter .007" as you deck height, then you just told it to go .007" below deck, hence the reason you are .4 off from me. You have to enter a negative number, as weird as that sounds, to be above deck and that calculator does not accept negative calculations .
