243 casting heads..
Old Jul 11, 2006 | 02:17 PM
98hardtopZ's Avatar
Default 243 casting heads..
i have found several sets of these on ebay for around 300 new. these are in fact ls6 heads right? and will they be a good upgrade from the ls1 241 heads?
Old Jul 11, 2006 | 02:19 PM
Xtnct00WS6's Avatar
Give us a link so we can check them out. If you buy them, you should at least mill them for more compression. Don't just go from 241 to 243. I don't think it'd be worth your while.
Old Jul 11, 2006 | 03:25 PM
dug's Avatar
dug
Dont forget to factor in the cost of head bolts and gaskets. Theyre over $100.
Old Jul 11, 2006 | 03:38 PM
viewsonic's Avatar
For 300 new the heads are bare for sure!
Old Jul 11, 2006 | 04:45 PM
Evans752's Avatar
About 30 horsepower to the ground is what I picked up.
Old Jul 11, 2006 | 04:56 PM
8GTOKLR's Avatar
Link to pics of ported 241's in sig. I spent less than 1100 for machine for work, valves, spring kit assembled. Added new lifters, gaskets, bolts was around 280, then labor fees to install was like 1800. its not cheap to make sure job is done right and with right parts. look to spend close too 2500 or more
Old Jul 11, 2006 | 04:59 PM
viewsonic's Avatar
why would you do that when you can get AFR's or ETP's???
Old Jul 11, 2006 | 06:01 PM
8GTOKLR's Avatar
cause heads were 100 and port work was under 500.. and they flow 290/192. you cant get that from AFR or ETP or anyone for 600 bucks
Old Jul 11, 2006 | 06:14 PM
viewsonic's Avatar
hmmm...
1100 + 100 for heads = 1200 bucks... Kinda expensive for a 241 head on your car...
290/192 at what lift?
My ETP 225's flow:
.650" 357/239
Old Jul 11, 2006 | 06:30 PM
8GTOKLR's Avatar
100 Heads
500 port
125 cleaning. machining etc
255 spring kit
200 valves
218 cc intake runner (210cc was stock)
290/192 @.660
284/184 @ .550
276/174 @ .500
flowed without pipe on exhaust side
216/224 @.050 .551 lift 115 lsa
Old Jul 11, 2006 | 06:56 PM
viewsonic's Avatar
100 Heads
500 port
255 spring kit
200 valves
290/192 @.660
284/184 @ .550
276/174 @ .500
Hmm kinda expensive for what it is.. but if you are happy that's all that counts.
What size chambers?
Old Jul 11, 2006 | 07:45 PM
93TAWicked1's Avatar
243 are a great upgrade depending on what your goals for the car are. I made 401rwhp without much tuning with Stealth II baby cam and 243 with the heavier 01 valves.
If you can get complete LS6 heads for 300 that just require a little bit of cleaning up. I'd have them milled a tiny bit and through them on. Looking at about 500 in heads and gaskets, bolts, fluids etc and a days work. I'm not counting the springs cause I'm assuming your doing a cam anyways.
For a reference point the prc Ls6's are going to be 899 for heads only minus good springs. So your talking about a 600 difference all things being equal.
If those are bare casting then its not such a good deal, might as well buy the PRC's or Patriots Imho. Or the forgetten head in these conversations the Dart 205.
Old Jul 11, 2006 | 07:50 PM
NoMoreFWD's Avatar
$1800 for install.
Old Jul 11, 2006 | 07:53 PM
Originally Posted by NoMoreFWD
$1800 for install.
LOL I didn't see that I hope that included all Lubercants with Vaseline.
Old Jul 11, 2006 | 08:57 PM
8GTOKLR's Avatar
85 per hr and its like 15 hours +-, head, cam, intake, exhaust, tune.
the heads were used 10K miles, cam was used 5K miles, thats savings right there.
Old Jul 11, 2006 | 09:08 PM
8GTOKLR's Avatar
oh yeah 64cc
Old Jul 11, 2006 | 11:51 PM
98hardtopZ's Avatar
http://cgi.ebay.com/ebaymotors/LS2-L...spagenameZWDVW
Old Jul 12, 2006 | 12:11 AM
LOL I have those on my watch list I'm guessing they will go to about 450-500 at that point I don't know that it is that great of a deal, when 900 will get you a set ported...
Old Jul 12, 2006 | 02:30 AM
98hardtopZ's Avatar
can you get anything for a set of stock heads on ebay? 98 year..
Old Jul 12, 2006 | 08:40 AM
radkon's Avatar
243 casting is the same as the ls6 (Z06) head however the Z06 has sodium filled lightweight valves which most ebay heads DON'T include.
