Just your thoughts
Old Jul 13, 2006 | 02:11 AM
FIVE-O's Avatar
Default Just your thoughts
Comp XE Grind 3755R/3756R HR112+2 (228/232 .538/.542) 110 CL
Dur @.006 281/285
VT @.050 open / close
int 4btdc 44abdc
ex 50bbdc 2atdc
After long hours of deliberation between my tuner and Comp, this was the end result.
Only other goodies will be LT's no cats, UD pulley and of course, a good tune.
This is not a daily driver that will see limited track use. Mostly just for ***** out fun.
Old Jul 13, 2006 | 02:51 AM
TroubledWine3's Avatar
I'm no expert but any reason you went small on the lift?
Old Jul 13, 2006 | 04:04 AM
Silver SS in Germany's Avatar
I have .560 lift on my cam. When I do heads I will do a new cam with about .615 lift. There was a really good article on being a cam expert. I think it was in Hot Rodding a few months ago. A smaller duration cam with more lift made more power then a higher duration cam with less lift. The higher duration cam just made a lettle more RPM.
Old Jul 13, 2006 | 07:04 AM
slow trap's Avatar
yeah,if it isn't driven all the time why not get the xer lobes with the same duration and pick up some power.i think it would be something like the 228/232 .588/.595 on a 112 +2 or a 110.
Old Jul 14, 2006 | 02:07 AM
FIVE-O's Avatar
Good points. They seemed to think I would be wasting the high lift on the stock heads...if that makes sence. And to save the valvetrain some.
Its still up in the air.
Thanks
Old Jul 14, 2006 | 01:04 PM
dnm12's Avatar
XER lobes.....i love them
Old Jul 14, 2006 | 01:13 PM
Studytime's Avatar
Thanks
A stock head can certainly benefit from more agressive lobes (i.e. lobes with more lift). Your peak lift will only occur for a short amount of time. Having a higher peak lift will allow your average lift to remain higher and will keep your stock heads in the areas they flow best longer than a low lift lobe.
Aside from a slight increase in maintenance, the more lift the better. LSK (most agressive Gen III hydrualic roller lobes to date) lobes would make more power than a lower-lift lobe with the same duration at .050" especially on a stock motor. When looking for good power with stock heads it's important to have a good lobe profile. As head flow potential increases lobe aggressiveness becomes less critical, but this is not your case.
Ben T.
Old Jul 16, 2006 | 04:34 PM
FIVE-O's Avatar
Wow! this whole cam thing is still confusing. I've had others state just the opposite. These days selecting a cam really is a crapshoot.
