how hard to maintain a cam only car?
My 98 z28 a4 is my everyday driver, but i only drive about 10 miles a day. I have long tubes, ory, borla catback, lid, ported tb, wires, bolt-ons. See, I am wanting to do a cam on my car and keep the stock heads. What is required to do this, and if i do this, how hard is it to maintain. People keep telling me that if I put a cam in my car it is going to screw everything all up and I am going to constantly having to work on it. Can someone please explain to me whether i should or shouldnt do a cam swap...How much difference does it make on the MPG too? i know the springs have to be changed about every 10,000 miles, but it is going to take me two years to put 10K miles on that car. I could use a lot of recommendations since my mechanic isnt informing me of the details involved in a cam only swap
thanks
sean
thanks
sean
I think that as long as you get a small cam, the only thing you will have to do is check the springs really, there shouldn't be anything abnormal to worry about.
after you get the cam installed though, I would definitely go get a tune to "not screw everything else up" and make it run correctly.
thanks for the replies, i am going to do it, any suggestions? I was thinking a 228/228. i dont know what springs to get, i am knew to this whole thing and have a friend that is going to be helping me do it. he said he would help me if I bought the parts, plus he can dyno tune it. any suggestions would be great, or links to the springs and cam i need. thanks
~sean
~sean
what kind of lift(.588?) and cam lobe(XE, XE-R, LSK...in order of less-more aggressive) you plan on doing with the 228 setup? just need to know this stuff when picking a spring. I have a XE-R 224/228 w/ .581/.588 lift aand using the Comp cam 918 single springs if that helps any
Originally Posted by LiveForSpeedZ28
also, how much will the cam affect my MPG, not that it matters really, just curious.
My MPG has actually improved since installing the 228R. I was running VERY rich before the cam swap and tune. ~17 mixed, 22+ Highway.
even some people with cams like the ms3 and similar i've heard of people going 20 k or longer and not having issues.of course that is not the norm and alot of people replaces them before then but you can always pull a couple and have them checked.a cam with an xe lobe even with a spring like the 918 should last a very long time with no maintenance whatsoever.
23k miles on my 224 cam. 63k on the car. No issues at all.
Have a new set of ls6 heads that i'll be doing soon (new 918's). Also am changing the lifters.
Car is well maintained, track driven and shifted at 6500 rpm WOT.
If you go w/ a good dual spring, they will last at least 20k pretty much regardless of what cam you are running. Valve springs are really the only added maintenence. Gas mileage will get worse the bigger you go. Stick w/ something in the mid to high 220's and you'll still get decent gas mileage.
LiveforSpeed, I see your car is an A4. Don't do a cam w/o doing a stall first. That will also hurt your MPG depending how big you go.
Something like a 3200 stall, and 224 cam would make a great DD and not hurt your mileage too bad.
