New 243 Castings $385.00 per pair !!
#61
Originally Posted by Gunnar@Patriot
Thanks for all the orders. If anyone has any questions about our sale, please let us know.
#63
Originally Posted by OJmobileII
received my heads yesterday and they look great. thanks for the deal.
Thank you very much. All of us here work hard to provide a great product at a terrific price. Keep us posted with your numbers.
#64
Originally Posted by muncie21
What would a set of 317's run with valves installed? If you don't offer 317's what the difference between those and the 035's?
We offer 035 castings which are basically the same. For non ported 035 heads with stock valves, the cost would be $400 plus shipping.
#69
I dont know much about heads right now but maybe you can clear some things up for me (a little anyway)...
whats the difference between these heads and a "good expensive" set of 1500-2000$ heads offered by other companies
do these have smaller intake and exhaust ports? whats the 243 refer to
thanks... sorry for my ignorance
#71
Originally Posted by a98ws6
What would I gain with going with the bigger valves?
Valve comparison – non-sodium filled oem (2.00/1.55) vs. Ferrea (2.02/1.57):
Ferrea are stronger, and will flow 1-4cfm more. These are better for max effort setups: SC, TC, or NOS.
Oem are lighter and cheaper; fine for a more mild, normally aspirated setup. These also provide more PTV clearance.
#72
1. New CNC ported 243 castings, 2.00"/1.55" (non-sodium) OEM valves, Patriot Gold dual spring kit, assembled, $995.00 per pair !!
#73
When it comes to a ported oem casting, our heads are among the best out there. They are assembled with the highest quality parts, brand new castings, and each head is custom prepared to your specs.
243 is simply the GM part number for heads that were used on the LS6 and LS2 motors. They are superior to the LS1 heads in terms of flow even in stock form.
As far as flow, our heads flow very well and for the money, can not be beat. Our runner size is 227 +/-. This is among the smallest CNC ported 243 runners available.
If you have any questions, feel free to call us.
#74
Originally Posted by ls1z01
How much is it for this kit with 918 springs & 035 castings with 918 springs?
They would be $835 plus the cost of the 918 springs. This would be for both the 243 and 035 castings.
#76
Originally Posted by 00'WS6Rocket
the shipping seems cheap $$ wise, just curious how much do these weigh? and how long is the wait from ordering to shipping?
An assembled pair weighs approx. 60 lbs. Our current lead time on ported heads will be 2-3 weeks.
#80
Gunnar, what would you reccomend for new setup:
Forged 347
-2cc pistons
T-Rex camshaft
ALL the bolt ons and mainly a drag car.
I want the compression as high as I can without hitting the valves.
Would you step up the valves?
Forged 347
-2cc pistons
T-Rex camshaft
You would probably be better off going with a set of our LS6 style 59cc heads. These will get the compression up there, but remain at deck height. You will still need to check your PTV clearance, but the 2cc reliefs will help alot.
