New 243 Castings $385.00 per pair !!
#85
Originally Posted by YankeeVert.
Gunner,
Do you offer the stock LS6 sodium filled valves as a option? If yes how much extra?
Thanks
Thanks
just get the bare option with a stock valve, seat job.
#87
Originally Posted by LS1IMPULSE
can i get a price on the 2.02 - 1.57's shipped to 17325
Either go big or stay stock. That way you have more PTV as well.
#88
GUNNAR, how can you do such a thing?! I'm trying to stay cam-only and here you are holding the forbidden fruit of sweet deal cylinder heads and ARRGGGG I cant hold back forever.
#89
Predator-Z is correct, the 2.02"/1.57" wil only pick up 2-5 cfm. We can do these with the Ferrea valves they will be $1195.00 for the pair.
#90
We just can't help it....our goal is to provide the quality products you need at the price you want.
#97
Hey Gunnar. Will the 243 castings with the OEM 2.00/1.55 valves have enough PVC for a cam like the MS4? With the stock valves, I would think that you would be pretty much safe with any cam, correct?
#99
I received my assembled 243 castings today and yes these are the excellent SPM versions (semi permanent mold castings) with triangles on head. My 402 is around the corner!
Thanks Gunner!
Thanks Gunner!
#100
Like Predator-Z said, If the stock heads will clear, these should be no problem. ALWAYS check PTV clearance.
