Mildly bolted on LS1 worth tune? or Cam?
#41
if your goals are 110+ traps and 12.99 or quicker...you could easily do that with just an ls6 cam and tune, leaving all else alone.
you could also do that by adding headers + ory / true duals. my gf's full weight 99 t/a m6 traps 108+ with a lid and blowmaster muffler...with her driving![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
she only traps 82 in the 1/8 then busts a 108 in the 1/4. i think the car could go faster, but she won't let me drive it.
#42
Originally Posted by Ubergeist
Weather was about 70, and humidity was 83 percent.
I thinkt he D/A ended up being 1300.
My 60' sucked, 2.350 and I got the time in sig. The only other thing is on that run along with others. I tapped the brake on the 2-3 and 3-4 shift.
But I was told that would not make that much of a difference.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
#43
#44
Originally Posted by blkZ28spt
You should be able to make your ET goal with an LS6 intake manifold, underdrive pulley and a little bit of driving practice. You might be able to make it with nothing but slightly better weather and a lot of practice. Your goal should be a 2.0X 60'. I know a guy that ran his M6 SS a total of about 113 times before finally getting a 2.0X 60'.........but he got there.
Are there any ill effects of the underdrive pulley? Undercharging, etc.
#46
You just convinced me not to get headers, lol. If I can put down between 330-340 with a tune. I will be happy. Most people I have seen that dyno LT's and y-pipe dyno at 350whp. Not worth the cash imo for 15-20whp. Maybe I am missing something, but what is a spec 3, I assume clutch?
The thunder CheatR how much additional whp are we looking at?
the tune also save you from haveing to buy sims and tune out all that **** you dont want like cags and traction control so know 120 off just for the sims and its only like 280 for a tune you cant buy parts that make 15-20 horses for 280 and plus your time to install or the money to get it installed its totally worth it dude
