oil on spark plug threads I WANT YOUR OPINION!!!
Originally Posted by just1news6
Hey thanks for the info that has to be the problem that is exactly waht mine is doing and with the oil eating as well THANK GOD SOME ONE KNOWS THEIR STUFF around here ive been told PCV so many times i think i could **** a pcv valve out my *** LOL
But see if there's any oil inside the inlet of the intake, just for the hell of it.
thanks i appreciate it the valve guides were on your stock motor right?
you have a point there lol anywho i appreciate it i think im going to do heads and cam this summer hopefully it will solve the problem. if not im going to get a stroker 402 but Thanks for all the help
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
The reason I ask is: After a long time of the oil getting sucked through the valve seals into the cylinders, you'll get a thick layer of burnt oil on the pistons. These oil deposits will cause hot spots all over the piston surface and it'll cause the pre-ignition (detonation) of the fuel/air mixture.
You can see how it built up on my pistons in this thread where I posted all the pics after we took my heads off. I cleaned the pistons like they were brand new and now on a hot as ***** day when it gets up around 210 the engine runs perfectly smooth, powerful and zero detonation.
https://ls1tech.com/forums/generation-iii-internal-engine/472364-5-springs-broken-good-thing-they-were-double-springs.html
This is just another way to be sure your oil is going through the valve seals.
to be honest i havent heard it detonating although we have the fans set at 180
