How much oil does your ls1 burn?
This past interval I have had to add at least 2 quarts. I never remembered how much I've had to add during this time around. I also switched to Amsoil 5W-30 from Mobil 1 5W-30.
Is it normal for it to burn this much? Before cam install it was maybe half a quart to one quart.
no ticks no slap, i consider myself having very very good luck finding my car... typically its 1 qt or so between oil changes... changing the PCV valve is prob a good idea too depending on miles Shell Rotella T 5W-40 Synthetic
There is no need for backup – I was just making a comment.
My diesel holds 10 quarts of the best oil (based on analysis and a ton of testing) and I still try to change it every five to six thousand miles depending on how I have been driving.
My Camaro on the other hand might see 100 miles in 3 months so I usually change the oil every four to five months just to keep it fresh. Still looks like Honey when I drain it out.
I'm on the end of my interval. Around 500 more miles and it will be changed. I change it every 3500-4000 miles.
