ARP Main Studs
Old Aug 3, 2006 | 09:47 PM
67Firebird455's Avatar
Default ARP Main Studs
I am really unsure guys, as this is the first ls1 I have built, do you replace the side bolts for the main caps or reuse? I have no idea if they are torque-to-yield like the main main bolts, which have been replaced with ARP studs (which when I received, I was shorted 5 nuts, so I'm waiting to see if the seller will help me out). Please let me know guys, I'm coming down the back stretch and I want to get it done correctly and need this information.
Old Aug 3, 2006 | 11:31 PM
Steve - Race Eng's Avatar
LS1TECH Sponsor
Default side bolts
Side bolts can be reused. Torque to 18 ft./lbs.
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old Aug 4, 2006 | 08:17 AM
Randy WS6's Avatar
You can get to ARP stud nuts from summit for around $6.00 and come two in a pack, that were i got mine at when i lost one.
Old Aug 4, 2006 | 11:07 AM
Zick's Avatar
I reused the side bolts as well.
Old Aug 4, 2006 | 12:42 PM
Great, thanks for the info! Trying to work out a deal with the seller to get them replaced, if not, at least I know where I can get some. I'll re-use my side bolts also, just wondered why the kit came with 10 extra washers (already used 1 under each nut) and 10 silver nuts (for the windage tray).
Old Aug 4, 2006 | 01:07 PM
strokedls1's Avatar
You can use the extra washers to space the windage tray away from the crank if you have a stroker 4" or bigger crank. The nuts can be ordered directly from arp as well.
Old Aug 4, 2006 | 01:11 PM
Okay, that makes sense, I figured that's what they were for to be honest, but just wasn't sure as I've never studded an LS1. Thanks a bunch for the info.
Old Aug 4, 2006 | 05:41 PM
Cop Car's Avatar
you can buy individual bolts from GM, its like $2 a bolt for the side bolts, personaly id buy new ones for that cost.
Old Aug 11, 2006 | 12:13 AM
What size exactly are the bolts? Are they 10mm x 1.25? Hope someone can help, about to order some arp nuts.
Old Aug 11, 2006 | 08:44 AM
Ferocity02's Avatar
With ARP studs, torque the cross bolts to 19ft-lbs. Use a good RTV sealant under the bolt flange to prevent oil seepage.
Old Aug 11, 2006 | 08:58 AM
racer7088's Avatar
Thumbs up
Call ARP direct Firebird as they are very nice and will replace those bolt or studs if you got shorted. We reuse the OEM GM side bolts too.
Old Aug 14, 2006 | 07:03 PM
I called Kammi @ ARP, got the nuts sent out this morning... Great people to work with, didn't think it'd be that easy! Thanks guys!!!
