Whats the biggest cam for a 346?
Old Aug 15, 2006 | 11:21 PM
blackls6's Avatar
Default Whats the biggest cam for a 346?
Yeah I have been thinking about going with a pretty radical cam for my motor since I will be staying all n/a. I was just wondering what is the biggest cam for a ls1/ls6 motor? Trex I guess? I was looking at the tsp giant but that seems to be for big cubes....or can that be used in a 346? Any imput is greatly appricated guys. I know the cons of big cams so that information will not be needed. Thanks again.
Old Aug 15, 2006 | 11:25 PM
BriancWS6's Avatar
Before you go for a cam, what else do you have as far as mods? Auto or m6?
Old Aug 15, 2006 | 11:42 PM
blackls6's Avatar
Sorry I should have listed my mods. I have full boltons, head/cam. I also going to be getting some pistons with valve reliefs so that ptv clearance with a big cam will not be an issue. I also have a m12 transmission.
Old Aug 15, 2006 | 11:55 PM
blackls6's Avatar
Old Aug 16, 2006 | 01:30 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Just because you can fit it doesnt mean it will work for you.
Old Aug 16, 2006 | 09:34 AM
00TAProject's Avatar
What is an M12 transmission?
Old Aug 16, 2006 | 09:56 AM
Landon@Texas Speed's Avatar
I'd recommend to you an MS4, its a max effort stock cube cam, and it will clear stock heads (if that is your plan) cause after that you're running REALLY tight piston to valve. The texas giant would only give you maybe 5-10 more peak hp, but at the loss of too much midrange on a stock cube motor
Old Aug 16, 2006 | 10:08 AM
Iron Sights's Avatar
I'm pretty certain that is the name for the transmission found in the C5 Z06.
Old Aug 16, 2006 | 10:38 AM
blackls6's Avatar
Yeah I already have the ms3 so going with a ms4 would kinda but a lot of work for not much difference. M12 is the transmission type for a z06(6spd). What about the T-rex? I have heard good things about that. Is that about the biggest anyone should go with stock cubes?
Old Aug 16, 2006 | 02:15 PM
blue2000Z28's Avatar
Well I think you could call Thunder and ask them for a custom cam. Im sure they would help. There number is on the side------>
Also, Iknow people always say that bigger isnt better, and I agree, but my buddy went with a t-rex and stage 2 head and they work oout GREAT. Great numbers..for an auto. So just try out different combos or call Thunder if your like me and like there grinds.
Old Aug 16, 2006 | 02:33 PM
GTO_Scott's Avatar
Here's the cam awaiting for me to install in my 346 LS1
Specs: 236*-240*-111*-.630"-.610"
a step up would be this one
Specs: 243*-247*-112*-.629"-.629"
Old Aug 16, 2006 | 03:31 PM
viewsonic's Avatar
Yah, it is a version of the t56.
It is also in GTO's
Old Aug 16, 2006 | 03:32 PM
viewsonic's Avatar
MMMMMMMMMMMM! The HELLION!
