car is smoking
Old Aug 20, 2006 | 02:55 AM
ls1marine's Avatar
Default car is smoking
so my car is smoking and i was wondering what are the main things that make a car smoke and how can u be for sure what it is
Old Aug 20, 2006 | 03:49 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
How long ago did you cam that car?
Old Aug 20, 2006 | 04:10 AM
SilverSS's Avatar
what color is the smoke? if it's oil it could be defective pcv system, bad valve seals, worn rings or cracked ringlands.
when does it do it and how often?
Old Aug 20, 2006 | 05:45 AM
35th SS's Avatar
do you have stock injectors what size? or bigger.
Old Aug 20, 2006 | 02:43 PM
ls1marine's Avatar
cam has been the car a while like 10000 miles
ls1marine's Avatar
smoke is white
Old Aug 20, 2006 | 02:44 PM
ls1marine's Avatar
they are the stock injectors and they are maxed out
Old Aug 20, 2006 | 05:12 PM
Billy177's Avatar
white smoke is usually coolant. pull the plugs to find out what cylinder it is
Old Aug 20, 2006 | 05:40 PM
ls1marine's Avatar
what do u mean what is up with the cylinder what would be amatter with it
Old Aug 20, 2006 | 06:05 PM
SilverSS's Avatar
might be a leaking head gasket. check your coolant levels.
Old Aug 20, 2006 | 06:14 PM
vettenuts's Avatar
If a cylinder is burning coolant, the spark plug will usually provide an indication so you can locate the leak.
Old Aug 21, 2006 | 04:16 AM
ls1marine's Avatar
if the cylinder is burning coolant what does that mean....or what is broken
ls1marine's Avatar
thanks man i will check as soon as i can
Old Aug 21, 2006 | 08:02 AM
Billy177's Avatar
it coulde be a bad head gasket or a cracked head. you wont really know until you tear it down
Old Aug 21, 2006 | 01:50 PM
ls1marine's Avatar
ok damn it but thanks man
Old Aug 21, 2006 | 01:54 PM
slow67's Avatar
Gingervitis Addict
Not necessarily. If he is running straight water, it may not show up on any of the plugs. Trust me, I ran a little Isuzu pickup 30K miles with a warped head. I only used antifreeze in the wintertime (Texas) and changed my plugs every spring when i started running straight water again.
Old Aug 21, 2006 | 03:02 PM
67Firebird455's Avatar
Yeah, sounds like a leaking head gasket. I wouldn't imagine it would be cracked, as the gasket is really the weak point. White smoke is not a good thing!
