Front/Rear cover alignment tools - are you using them?
Old Aug 21, 2006 | 10:12 AM
VTC_WS6's Avatar
Default Front/Rear cover alignment tools - are you using them?
Just wondering who is actually using (or has used I should say) the front/rear cover alignment tools? I'm gonna be putting the front and rear covers along with the oil pan onmy newly assembled motor soon and I'm getting mixed input as to whether or not they are really neccesary. I'm pretty clear on setting up the pan so it doesn't protrude from the rear so as not to interere w/ the bell housing, and the crank snout give me a good indication of aligning the front cover, same with the rear, anybody had problems eye balling it?
Old Aug 21, 2006 | 10:47 AM
GregWS6&z28's Avatar
front cover should be fine tightening down after you get the crank pulley seated. the back cover you may need a tool for.
Old Aug 21, 2006 | 10:51 AM
Bill Bowling's Avatar
I never used a tool for the front one but what I have read you should use one for the back.
Bill
Old Aug 21, 2006 | 10:57 AM
crazykid's Avatar
Restricted User
Yep I use it for both
Old Aug 21, 2006 | 11:31 AM
Beast96Z's Avatar
https://ls1tech.com/forums/generation-iii-internal-engine/558064-oil-pan-install-help-alignment.html This was on the first page, not to far down from your post. Read the instructions I posted in there.
Old Aug 21, 2006 | 12:03 PM
VTC_WS6's Avatar
Originally Posted by Beast96Z
https://ls1tech.com/forums/showthread.php?t=558064 This was on the first page, not to far down from your post. Read the instructions I posted in there.
Sorry didn't notice it, I'll check into it now though thanks!
