View Poll Results: How many times have you hit the rev limiter
1-10 times
209
37.12%
11-20 times
73
12.97%
21-30 times
35
6.22%
31-40 times
13
2.31%
41-50 times
5
0.89%
51-60 times
5
0.89%
i ve hit it so many times i cant count
159
28.24%
i ve never hit it
48
8.53%
my motor is indestructable
33
5.86%
Multiple Choice Poll. Voters: 563. You may not vote on this poll
How many times have you bounced off the revlimiter?
#64
I've hit it a few times. With my Raptor in the car i've yet to miss one. The tach seems to be a bit slow in the first two gears (in my car anyway), hence the need for the shift light.
Jon
Jon
#67
The most common problem from over-reving would be bent pushrods and valves hitting the pistons. Ive seen lots of both. If you dont want this to happen, get LS6 stlye heads with the hollow valves. GM knew what they were doing here, ask anyone with a Z06....What are the limiters set at on these things, I think its like 6600? Lighter valves = no valve float. Happy revving!
#71
limiter
Originally Posted by azceta
i bang the limiter more that i beat my meat and thats at least 5 times on a bad day
I hit the limiter all the time because my 4l60-e is a p.o.s
As long as the valvetrain can take higher rpm than the limiter no big deal.
but if you are useing valve float to limit or right at that point with the limiter setting you are asking for that piston to smack the valve.
mike
#74
I hit it a few times before and after a cam swap. no bent pushrods. As a matter of fact, i took my heads off today and checked the pushrods, still none bent. Before you ask, i took them off to change the lifters, 875 comp/r's crap.
#75
Custm2500's #1 Fan
spinning a cammed 5.3 to 6400 with no problems on a 150 shot... limiter is set at 6600... Never hit it while spraying though. the limiter is a FUEL shutoff if I'm not mistaken.... that would be ugly to bounce the limiter while on the bottle :boom:
#76
#78
I am new to this site, but wanted to chime in here.
I have an LS1 in my Sand Rail.
Lots of people here in the southwest that go to the sand dunes run LS1, LS2, LS6 and LS7's are starting to become popular.
I can tell you, we run these motors very hard.
I am running at 4000-5500rpm all the time in the sand.
As far as rev limiters go, people hit them all the time at the drag races or running big hills.
I haven't seen anyone have a problem yet.
The pix I have of the motor is too large, I will see if I can get a better one.
Thanks
Thanks
