View Poll Results: How many times have you hit the rev limiter
1-10 times
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
209
37.12%
11-20 times
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
73
12.97%
21-30 times
![](https://ls1tech.com/forums/images/polls/bar4-l.gif)
![](https://ls1tech.com/forums/images/polls/bar4.gif)
![](https://ls1tech.com/forums/images/polls/bar4-r.gif)
35
6.22%
31-40 times
![](https://ls1tech.com/forums/images/polls/bar5-l.gif)
![](https://ls1tech.com/forums/images/polls/bar5.gif)
![](https://ls1tech.com/forums/images/polls/bar5-r.gif)
13
2.31%
41-50 times
![](https://ls1tech.com/forums/images/polls/bar6-l.gif)
![](https://ls1tech.com/forums/images/polls/bar6.gif)
![](https://ls1tech.com/forums/images/polls/bar6-r.gif)
5
0.89%
51-60 times
![](https://ls1tech.com/forums/images/polls/bar1-l.gif)
![](https://ls1tech.com/forums/images/polls/bar1.gif)
![](https://ls1tech.com/forums/images/polls/bar1-r.gif)
5
0.89%
i ve hit it so many times i cant count
159
28.24%
i ve never hit it
48
8.53%
my motor is indestructable
33
5.86%
Multiple Choice Poll. Voters: 563. You may not vote on this poll
How many times have you bounced off the revlimiter?
#83
countless times, never a problem. All my valves were perfect when I had my heads rebuilt after 4 years, valve seals were gone.
I may burn oil like alot of big strokers, but I don't think my engine can break, from anything.
Whats the most common damage that occurs from hitting the rev limiter anyway?
#87
how much oil do you burn? Man it sucks, I could go through 1/4 court in a night if i'm driving it hard. Close to 1qt in 1k miles. Shitty!
#88
I put engine Honey in it this past weekend when I left Lauderdale to come back to Orlando, two bottles in place of 1 quart of oil during an oil change. When I got to Orlando I checked it the next morning and it was only 1 1/2 qrts low, that **** works. So, about $15.00 a week in oil.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Oh well ,new engine coming very soon.
#89
It didn't burn any oil for about the first 6 months, than it gradually got worse. Now, and I ain't shittin ya, I burn 1 qrt every 100 miles. Every time I drive to Lauderdale from Orlando, which is every weekend for the past year (210 miles one way), I fill it before I leave and its 2 quarts low when I get there.
#90
Your rings, or what?
#91
From what I'm told: The sleeves in my 5 year old LS1 are short. The 4.125 stroke I have has the piston traveling so far down the sleeve that at BDC it rocks back and forth more than normal and causes pre-mature wear of the rings and the cylinder walls. But my builder also told me a couple weeks ago that my oil ring, I think the top oil ring, is .043 size, which is looser than it could have been. ARE built engines back than for big shots of spray so I guess they used rings for that use and not for what I wanted, which was 100% street use and N/A only.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#95
all the time when i have to be dramatic and/or scare people with the cutout open. but other than that i dont do it much. broke a valve spring but dunno if it was from that necessarily.
#96
So between the premature ware, and big ring gaps for big shots of nitrous.... big oil consumption. That blows bro. I think thats why I consume oil, cause my rings are set for a 200 shot. Thems the breaks I guess.... ![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#97
Originally Posted by lovescamaros28
over-revving is very dangerous to an engine.Everything becomes out of time and sync.Lifters bounce off camshaft lobes and engine wear is increased substantially.
Just trying to get you on the same page the rest of are. I feel we're talking about two different things here.
Ben T.
#99
11 Second Truck Club
Everytime I see an Import!!!
I have it set to a 3800 cut out, 3750 cut in, while I'm in neutral.
I like the look one their face when I drive by a parking lot full of hondas and hang the limter out there for about 5 seconds.
