Is this a streetable cam for an LS 5.3?
Old Aug 28, 2006 | 11:15 PM
Built LT1's Avatar
Default Is this a streetable cam for an LS 5.3?
I found this custom grind at Thunder Racing.
.600/.523 214-220@.050 115+2 LSA
While I have other minor mods in the works to increase the total number of horsepower, I am looking to gain 25-35 of those rwhp to to my '04 5.3 liter Tahoe via a cam swap.
I would prefer a cam that does not require computer tuning. Most of all I want it to have close to stock like drivability.
The other mods are a K/N FIPK and a Magaflow straight through muffler. Just looking for a noticable increase over stock.
Old Aug 29, 2006 | 12:26 AM
PREDATOR-Z's Avatar
All cam swaps require computer tuning, otherwise why bother.
Old Aug 29, 2006 | 12:49 AM
Built LT1's Avatar
If that is what it requires I can live with it. A tune will also bring more power so this isn't so bad. Assuming a proper tune, will this cam be too big?
Old Aug 29, 2006 | 12:51 AM
1slowls1's Avatar
with a good tuner i believe any cam could be made street
able
Old Aug 29, 2006 | 01:40 AM
Built LT1's Avatar
So how much power would that cam make rear wheel?...20?...40?
Old Aug 29, 2006 | 04:27 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
35 probably. All depends on how it mesches with your other mods.
Old Aug 29, 2006 | 04:28 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I would say around 35. Also depending on how well the cam mesches with the rest of your setup/mods.
Old Aug 31, 2006 | 05:02 PM
Black Z28 M6's Avatar
As long as you dont go over 220 DUR@.050 you will OK
Comps 212/218 114LSA is pretty good (Xtreme RPM) 1200-6000 Powerband
