negative effects on lowering rev limit?
I guess my actual beenfit should be..how much damage does hittting the stock limiter cause(I know you could bend a pushrod or have valve float)..would lowering it eliminate that?
to be honest, upgrade the driver. if you dont make power over 5500, then shift there. dont give yourself another crutch to depend on...
I do shift there..at the drag strip...but auto crossing is different.
instead off learning when to shift yourself depending on the situation, reprogram the PCM. whatever floats your boat. and it IS a crutch. if you can't learn to avoid the rev limiter through practice, then forcing the PCM to lower it for you so you dont have to worry about it IS a crutch.
But you seem to be taking this personally now, so do whatever. it wont hurt anything to lower it.
Leave the limiter where it is. Its not the limiter thats causing valve float, its mechanically overrevving it thats causing it. Just dont stick it in the wrong gear.
Al
