What's the best cam?
Old Aug 30, 2006 | 11:42 AM
S3R's Avatar
S3R
Default What's the best cam?
What would be the best cam to go with for an LS1 with bolt ons, and why?
Old Aug 30, 2006 | 11:51 AM
98Z28CobraKiller's Avatar
Restricted User
Use the search button. This subject has been covered atleast 100 times and there is no "best". It depends on the intended use and the required drivabilty.
Old Aug 30, 2006 | 11:57 AM
S3R's Avatar
S3R
Surely there must be one that stands out as better for performance/driveability.
Old Aug 30, 2006 | 11:59 AM
SUTTERERMAN85's Avatar
there are like a 100+ good cams. there is no BEST overall cam. you need a cam that will work best for you. you really need to ask yourself what are you going to be doing with the car and how much are you going to be driving it? use the SEARCH button too.
Old Aug 30, 2006 | 12:02 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Old Aug 30, 2006 | 12:05 PM
Originally Posted by Lithium
224 224 112
was waiting for some one to post that, lol that is a good DD cam and has a really good power band.
Old Aug 30, 2006 | 12:08 PM
Pipelayaz's Avatar
close this thread
Old Aug 30, 2006 | 12:09 PM
LFNDUST's Avatar
230 / 236 woot
skewba98z28's Avatar
Best cam=figure out your application whether it is race or street then use the search button.
Old Aug 30, 2006 | 01:36 PM
SVT THIS's Avatar
Give him a break, search is down. But, some things you need to consider on paper before you buy a cam new LS1tech'er is....
What heads, bolt ons, intake will you be running? Street car? Daily driver? Track only? Street/strip? Street race? Weekend car? Goals-nice DD, some bad manners, disgusting, insane? How much do you want to spend on valvetrain, rear end, suspension, tranny? How big of a cam could you drive everyday? Live in the country? The city? Commute? Want power down low, midrange, up top? Plan on running gears or stall? Any weight reduction?
There are probably at least 467 other variables to consider. Trust me, I posted roughly a thousand questions over cam selections, as have most members here. When the search feature starts working again you could read for a year and never find a "best" cam.
Old Aug 30, 2006 | 01:40 PM
orangefun's Avatar
I know this does not have anything to do with this post, but what is up the search being so jacked up. plus you can not blame the guy if the search engine is down.
Old Aug 30, 2006 | 01:51 PM
allngn_c5's Avatar
Damn everyone is slamming this guy. I am a big LG Motorsports supporter and they have 4 kick *** cams for the LS1. G5X1 and X2 are more daily drivable and less peak hp. The G5X3 and X4 are both wicked. All out hp/tq on the top with decent mid and low rpm power. The G5X3 and X4 also require flycutting with milled heads, and significant Valvetrain upgrades. 921 comp dual valve springs and hardened push rods, also Titanium valve seats. This will let you run the X4 to 7000 rpms, but not all day everyday. Big cams need big maintenance, new valve springs every 30k miles. Keep that in mind. Hope this helps you out a little bit. The number to LG Motorsports is in my sig. Ask for Bobby.
Old Aug 30, 2006 | 01:54 PM
ChocoTaco369's Avatar
Tech Resident
asking "what is the best cam" is like asking what is the best topping on a pizza. some like pepperoni, some like sausage, some the works, some like plain. there is no "best cam". now if you said "which is the best cam for an A4 w/a 3200 stall, 3.23's, N/A motor, looking to hit mid 11's", then we could help you. you gotta be more specific bud.
what mods do you have? what are your goals? is it your daily driver? what tranny do you have? gear ratio? etc...
Old Aug 30, 2006 | 02:10 PM
import slayer's Avatar
[QUOTE]asking "what is the best cam" is like asking what is the best topping on a pizza. some like pepperoni, some like sausage, some the works, some like plain. there is no "best cam". now if you said "which is the best cam for an A4 w/a 3200 stall, 3.23's, N/A motor, looking to hit mid 11's", then we could help you. you gotta be more specific bud.
[QUOTE]
good point
Old Aug 30, 2006 | 02:53 PM
eamador11's Avatar
Old Aug 30, 2006 | 02:55 PM
eamador11's Avatar
that doesnt matter, if there was a best cam, dont you think the entire world would have it?
Old Aug 30, 2006 | 02:56 PM
Blacked Out's Avatar
I like pepperoni and mushroom
Old Aug 30, 2006 | 02:57 PM
eamador11's Avatar
huh? but i was told my cam was the best so i bought it. you mean I dont have the best cam??
Old Aug 30, 2006 | 03:14 PM
GuitsBoy's Avatar
Bigger cam = more power.
Bigger cam = less drivability.
more power = less drivability.
weigh your options and make a decision.
Old Aug 30, 2006 | 05:27 PM
s346k's Avatar
t-rex
