View Poll Results: meanest sounding cam
T-rex
228
58.02%
MS3
86
21.88%
G5x4
53
13.49%
FM 15
26
6.62%
Voters: 393. You may not vote on this poll
poll: meanest sounding cam
Old Sep 20, 2006 | 08:46 AM
  #41
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
A couple of Australian Cams.
273/273 104LSA / 104 ICL <- In Craig's old 346 with an Auto.
258/262 .644/.661 107.5 LSA <- Supercharged motor
But in all actuality, the meanest sounding cams are the ones that are optimized for amotor. They don't just lope, they actually "crack". Best way I can describe it for you is to tell you to go listen to a Pro-Stock motor run. Its not rumble, rumble, rumble its crack, crack, crack.
Old Sep 20, 2006 | 01:32 PM
  #42
TAGOES11S's Avatar
Great thread!
Cam's do change how a car sounds, so do mufflers. People want there car to look and sound and perform a certain way. So for all of you that have ragged on this thread, take of your exhaust, don't clean your car, because obviously sound or looks don't matter to you.
Nothing better than a sweet sounding cam'd car!
Old Sep 20, 2006 | 07:42 PM
  #43
Beasst8's Avatar
I just cranked up my MS4 for the first time and LOVE it. Sounds great. Will be getting a dyno tune in the coming weeks. I have a base tune in it for now. I can tell its running a little rich though. Anyway, MS4 is sweet
Old Sep 20, 2006 | 08:14 PM
  #44
one2run's Avatar
LG cam grinds sound fuggin mean! G5, of course i am biased.
http://s73.photobucket.com/albums/i2...ldstartTDs.flv
Old Sep 21, 2006 | 04:42 AM
  #45
Freak's Avatar
Originally Posted by N4cer
Wow, I have ZERO overlap. Can that be right?
No, its not right. Looks to me like you are using the .050 lift duration figures. Overlap is calculated from the instant both valves are open, so the advertised numbers are more accurate (though they are also measured at a specific lift so they wont be exact)
Old Sep 21, 2006 | 09:32 AM
  #46
moeZ28's Avatar
When I did the calculation for my TREX (specs off cam card), I came up with 26.1 degrees of overlap.
Old Sep 21, 2006 | 09:36 AM
  #47
N4cer's Avatar
You suck, Moe! You and your MONSTER biggest of the Trex. The Trex-Rex.
Old Sep 23, 2006 | 05:47 PM
  #48
mr2guru's Avatar
http://videos.streetfire.net/search/...39007816ca.htm
That right there is the meanest sounding cam I've ever heard on an LSx....
Old Sep 23, 2006 | 10:34 PM
  #49
agrV8dta's Avatar
AMEN!!! I can listen to that video all day long
Old Sep 23, 2006 | 11:40 PM
  #50
Irocss85's Avatar
Originally Posted by Asmodeus
Where's the Hellion option?
SUBZERO, FIGHT!
yes!!!!! where'd you get that avatar?
Old Sep 24, 2006 | 04:28 AM
  #51
studderin's Avatar
2strokeracer/ hellion
http://studderin.livedigital.com/content/98773/
Old Sep 24, 2006 | 12:43 PM
  #52
CrawlinWS6's Avatar
Import Patrol
Here is a sound clip of what my car sounded like with the trex
Old Sep 24, 2006 | 01:24 PM
  #53
import slayer's Avatar
What kind of exuast set up do you have?
Old Sep 24, 2006 | 03:07 PM
  #54
cws T/A's Avatar
http://video.ls1tech.com/category/Ca...67516f3c93.htm
http://video.ls1tech.com/category/Ca...76c9f70728.htm
http://video.ls1tech.com/category/Ca...23cf795658.htm
http://video.ls1tech.com/category/Ca...a3ad663d29.htm
http://video.ls1tech.com/category/Po...6ef7df9530.htm
http://video.ls1tech.com/category/Po...324b0651b9.htm
a beast of a cam 52 degrees overlap
http://video.ls1tech.com/category/Ca...d35da468f9.htm
Old Sep 24, 2006 | 05:04 PM
  #55
N4cer's Avatar
"Trans Am 408 Soundclip" sounds the meanest.
Old Sep 24, 2006 | 08:04 PM
  #56
purdueranger's Avatar
I have heard the G5X4 and it sounds mean. I am sure it pulls good too.
Old Sep 24, 2006 | 08:05 PM
  #57
CrawlinWS6's Avatar
Import Patrol
If your talking about mine. I had mac midlengths, and magnaflow cat back
Old Sep 24, 2006 | 08:17 PM
  #58
Asmodeus's Avatar
Originally Posted by studderin
that is just sexy..
Old Sep 27, 2006 | 09:31 AM
  #59
BAN-LS1's Avatar
I guess exhaust has a lot to do with it. Most of those cars sound like popcorn makers I think my F15 sounded pretty damn mean! F15
Old Sep 27, 2006 | 09:43 AM
  #60
CrawlinWS6's Avatar
Import Patrol
Damn dude you must be def! Listen to yours. I sound like a damn popcorn maker as well!
