is it dumb
Old Sep 11, 2006 | 12:41 AM
SLP4CamaroSS's Avatar
Default is it dumb
is it dumb to run a cam with only .588/.574 lift and use prc spring that are rated to .660? any pros or cons on this?
Old Sep 11, 2006 | 12:42 AM
LS1firebird95's Avatar
no just a little bit of over kill
Old Sep 11, 2006 | 12:47 AM
just seems cheaper goign that route cant find a good package deal with 918 springs
achilles's Avatar
uh usless really
Old Sep 11, 2006 | 12:50 AM
http://cgi.ebay.com/ebaymotors/COMP-...cmdZViewItemis that the kit i need. are they the right pushrods i got a g5x1 114lsa 228/232 .588/.574
Old Sep 11, 2006 | 12:55 AM
00454sscamaro's Avatar
alittle harder on the rockers, lifters pushrods etc..and might loose a very small amount of hp. but i would think the springs would last alot longer then ones rated closer to your lift.
Old Sep 11, 2006 | 01:11 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You can run a dual spring and be perfectly fine. I run a 918 on my cam.
Old Sep 11, 2006 | 01:20 AM
SuperZ's Avatar
i have a 550 lift cam with those springs.I would like the reasurance
Old Sep 11, 2006 | 02:13 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You also have a forged motor that you can probably crank up to 7k no problem. I would want durability at that point as well.
