Are Heads worth the Money?
Old Sep 20, 2006 | 01:03 AM
00Formula00's Avatar
Default Are Heads worth the Money?
just have a quick question, i am planning headers, camshaft, and new exhaust system....anyone think whether new heads are worth the money...$1,000, how much hp?
Old Sep 20, 2006 | 01:11 AM
SSilverSSurfer's Avatar
sometimes people get buy without, of course theyre good, thats why they cost what they do, heads can make you or break you
Old Sep 20, 2006 | 01:34 AM
jdoyle's Avatar
oh hell ya. depending on the application, the possibilities are endless.
if you can only spend 1000 on heads, id def see where that could get you.
Old Sep 20, 2006 | 08:16 AM
GuitsBoy's Avatar
Yes, many of the 1000 dollar heads will potentially net you better than 30HP. It might take another 1500 dollars to put an extra 10 HP on top of that with the super premium heads.
Old Sep 20, 2006 | 08:27 AM
Steve Bryant's Avatar
LS1 Tech Veteran
Good cylinder heads set the stage for every other modification you plan. This doesn't mean you have to have the best. However, properly done, a basic pocket porting of the bowls and a mild cleanup (removing flashing, irregularities, etc.) of your own heads will yield a good improvement. Good heads will make the proper cam for your application really shine. If I were going to rank fundamental improvements, I'd say to do heads, cam and headers (in that order). However, if you are going to pull the heads, I'd wait till I had the money for a cam since you already have the engine torn down anyway.
What are your goals for your car?
All my best,
Steve
Old Sep 20, 2006 | 08:33 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Even ported stockers are good! Mill and mild port can work wonders. I would suggest the LS6 intake on top of that if you don't already have one.
Old Sep 20, 2006 | 01:53 PM
99_Z_155's Avatar
i too am looking at heads. i have a 233/239 cam with .600/.605 lifts. i have headers, and a mail tune from TSP. i dynoed like 370 without a real tune, running a bit lean. would a set of LS6 ported heads and LS6 inake net me over 400hp? after i do that im thinking of throwing nitrous at it, but thats another story. i am now employed at a chevy dealership, and can get good deals on parts. i was thinking i could get the LS6 heads for like 6 or 700. what do you guys think of that? Dont want to hijack, maybe this info could help out others...
Old Sep 20, 2006 | 02:47 PM
eamador11's Avatar
Yes, heads are the heart of the motor so dont skimp on them.
Old Sep 20, 2006 | 03:26 PM
Ryan02SS's Avatar
Heads are the equivalent of your brain. Power is made in the top end while the bottom end simply handles it. You would not skimp on brain surgery so you would not want to skimp on your cylinder heads.
Old Sep 20, 2006 | 03:57 PM
dalejr8ls1's Avatar
to be short... YES
Old Sep 20, 2006 | 04:11 PM
BriancWS6's Avatar
I've been cam only with my last car and heads/cam with this one. Guess which one I like better
Old Sep 20, 2006 | 04:24 PM
Cop Car's Avatar
you can get new 243s for like $400 or something, you can find used ones cheaper. the benifit of those is that you can increase your compression (adds hp) without loosing piston to valve clearance. plus they flow better. since you are on a tight budget you should look at patriot ported heads, for like 1200 you can have awesome heads.
also while you have the heads off you might want to think about replacing your lifters with GM stock replacements. $125 from GMpartsdirect. knowing you wont have to remove your heads again is a nice feeling...
Old Sep 20, 2006 | 04:52 PM
LS1IMPULSE's Avatar
patriot claims 40HP gains on their 243 castings, i beleive they are $1195 assembled with PRC golds, i dont think they are currently listed on the patriot website so you may have to PM gunnar if interested.
Old Sep 20, 2006 | 08:24 PM
so whats the deal with buying used heads versus new ones....are there any downfalls in ones that have already been ran on???
so say im going to get LT headers, 5.3L partriot heads and a 228 cam...anyone have a guess on hp numbers for that? to the wheels?
Old Sep 20, 2006 | 08:28 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Well, sometimes portwork/valve angle jobs can wear down a bit over time/usage.
Depends on if you are a M6 or an A4 and what other bolt-ons you have done. Drivetrain loss through an automatic will cause you to actually dyno less. Doesnt mean it is any weaker powerwise though.
Old Sep 20, 2006 | 10:33 PM
ya i have the A4
ummm i only have exhaust and cold air intake....so get a new set of heads if im gonna do it....
so say i have the extra money saved for the heads...is it worth it or should i spend that money somewhere else
Old Sep 20, 2006 | 10:57 PM
austin21's Avatar
which are better 205 or 243 ... i have a 232/240 595 608 cam installed already
Old Sep 20, 2006 | 11:21 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Cam = Heart (think about it)
Well, honestly you can make all the power in the world, but you have to be able to plant it to the ground. That is where it is going to count. I would do suspension mods before I did heads. You have the power right now to go 12's in the 1/4. I think that you will benefit from the supporting mods. Hell, the horsepower you have now is over powering what you can actually use. Subframes, Torque arm, LCA's, Panhard rod, Sway bars, Upper and lower A-Arms, Tubular K member, Poly motor mounts, Poly Transmission mounts.....just to name a few. You can get a good chunk of that for the price of heads. When you are ready to do heads your gonna have a monster.
Old Sep 20, 2006 | 11:22 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
243 is the LS6 casting. I would go for that before anything else, unless you are trying to raise your CR.
Old Sep 20, 2006 | 11:53 PM
Blackout6's Avatar
money not being an concern, what are the best heads straight up?
