labor cost on forged bottom end??
Old Sep 21, 2006 | 06:01 PM
TryingT/A's Avatar
Default labor cost on forged bottom end??
If I don't sell the t/a, then I will want to supercharge it (probably f1 procharger) I would need a rearend, ds, and forged pistons beams and I will probably just use gm crank. I know this will cost around 10gs, but I'm trying to allocate the costs, to see would I can do first or whether I should do it all at once and try getting a package deal.
What kind of labor costs were incurred for forged bottom end (motor will have to be ripped out right?)
labor on the rearend> and if I get a moser 9: will I have to get diff torque arm??
I think alabor on s/c was like 800 bucks so that's no so bad.
People that did their own labor: good for you, you saved a shitload of $$. But I will most likely have a reputable shop build it for me.
Any input would be great.
Old Sep 21, 2006 | 06:26 PM
TryingT/A's Avatar
You people too ashamed to admit what you paid??
Old Sep 21, 2006 | 06:49 PM
Cop Car's Avatar
the assembly cost on my motor was free
Old Sep 21, 2006 | 06:57 PM
TryingT/A's Avatar
Why?? DIY? Free labor cause you bought their parts?
Or are you just mr. Fantastic?
Old Sep 21, 2006 | 10:47 PM
TryingT/A's Avatar
You guys are a huge help!
Thanks
Old Sep 21, 2006 | 11:12 PM
Insanekamel's Avatar
maybe he bought a forged shortblock....
Old Sep 21, 2006 | 11:20 PM
jamesSS's Avatar
im curious too. common guys, help us out. ive seen your sigs, i know your out there.
Old Sep 21, 2006 | 11:47 PM
jay_99z's Avatar
I really don't know about labor. I never made it that far. When I started pricing out the parts and then looked at the prices from some of the sponsors fully assembled.....I figured why bother? It was only a couple hundred bucks more to get a fully assembled shortblock from Texas Speed. And they know what the hell they are doing. I didn't have a shop close to here that I trust.
Old Sep 21, 2006 | 11:50 PM
true but if you are staying stock cubes why buy another block...
Old Sep 21, 2006 | 11:52 PM
Marc '99T/A's Avatar
You gave 25 minutes before you posted this. Give it some time.
Thanks
Before you start bashing people on this board, give the thread a little time (again). Also, shoot the sponsors who deal with this a PM or give them a call; they can give you an idea.
Old Sep 22, 2006 | 12:08 AM
jay_99z's Avatar
New block was $599. I can sell mine for a couple hundred and get some of that back. Like I said though....I didn't have someone close I would trust to build it. Saving a couple hundred on and engine doesn't mean much if it explodes. I guess the point is.....you can get a great deal from the sponsors and might not save much going local. Unless you have a great builder close by...
Old Sep 22, 2006 | 12:12 AM
Cop Car's Avatar
yes, i am in fact mr fantastic, but thats not why..
i put it together myself mainly because im the only one id trust with it.
Old Sep 22, 2006 | 04:42 AM
TryingT/A's Avatar
At 33k miles, I would really like to use my block , but 600 bucks isn't that much for a block. And if it's better to start of with a bare block, build the bottom end and just switch over the top end, then that might be a good solution. Speed inc. is a half hour from me, so that would probably be the place that i'd go.
Old Sep 22, 2006 | 02:32 PM
Cop Car's Avatar
then buy a 408 cast iron block stroker motor, put L92 heads on it, L92 intake on it then..sell your motor.. if not sell your complete motor and trans.. and get an upgraded trans at the same time.. your motor/trans should bring in the 4k range.. and i think you would end up comming out better in the long run
Old Sep 22, 2006 | 02:36 PM
jay_99z's Avatar
If your engine is running right now.....that's a no brainer. Sell the shortblock and put that $$ towards the new one. You'll get more than enough to buy a new block.
Old Sep 22, 2006 | 02:37 PM
Dub C's Avatar
$800 to remove and reinstall motor. $400 for machine shop to hone the block and whatever little stuff they do. $500 to reassemble the motor.
Old Sep 22, 2006 | 06:39 PM
smokin t/a 600's Avatar
I am paying 300 for my new rearend to get installed along with a new driveshaft.
Old Sep 22, 2006 | 07:02 PM
calongo_SS's Avatar
If you're not doing the work yourself, 10k is no where near enough for a F1 procharged car, even if you were, it's still not enough.
Old Sep 22, 2006 | 07:16 PM
LS1IMPULSE's Avatar
1.) you should certainly be able to swap the rearend on your own especially if buying one that is already fabbed for your car, you may be a new TQ arm, i have the Spohn, and you will mostly likely need a new driveshaft that will be a different lengh than stock.
2.) buy a new shortblock:
http://www.texas-speed.com/shop/item...mid=42&catid=3
TSP 347 CID for 2800 and you may even be able to get better pricing elsewere or by calling?
You say you live by Speed Inc? Then search through their website a little http://www.ls1speed.com/enginepackages.cfm You can get the sportsman 348cid complete engine, installed, and dynotuned for $7500, sell your whole engine for 4K and youve got a brand new 348 installed and tuned for $3500, not bad?
Whatever you do i think you need to a lot of reading before you buy anything, if you want a SC you may want to talk to Speed inc about a different cam being put in the engine, the ls1tech search button is finally working agian, so you may want to use it.
Old Sep 29, 2006 | 09:13 PM
TryingT/A's Avatar
Buying a stroker motor is very tempting, it's common for most users on this site to have at least a 402. Buying a forged shortblock was the original plan, but it's a shame that I try to keep the miles down only to drop in a new engine.
What would that do to the value of the vehicle?
If I was buying a low mileage car with a new engine, I would ask myself what that owner was doing with the car to cause the engine to go. But how many f-bodys are stock anymore?
Would only the engine bring in $4000, or the trans and engine? It would be at least 2gs for a built t56, but that would be the best route if everything is getting replaced anyway.
