Need opinions on which block to choose
I was thinking of using the 6.0L iron block for a foundation. Any input on this block and it's capabilities would be much appreciated! I saw an LS iron block on GM Parts Direct p/n 12572808 9.240" deck height, 3.98" bore, 6 bolt main, nodular cap material, standard LS crankshaft journal diameter. wet oiling, 1 piece seal, 4.00" max stock, 500 max horsepower, street usage, LQ9 origin
Would this be an acceptable block for this build up? Plans are looking like to stroke it, run around 7-10 psi. boost level, no No2, no sure baout cam, intake, valvetrain and specs. on bottom end. Just trying to take this one part at a time to ensure a proper build.
Any input would excellent and appreciated.
The 100 pound or so weight penalty is not very much when you consider the durability of these blocks at high power levels under boost.
Just my opinion.
Steve
The 402 might be better to do first, then the STS... There is a slight chance you can hurt a stock piston at 500rwhp... the 402 just warms up at 500rwhp
