engine floodes after cam swap
I just did my cam swap with 01 heads and it is running pig rich I will not be driving it till I tune it but I took it around the block and I noticed I lossed a bit of oil pressure . I dumped the oil and there was a lot of fuel in it .
I am sure the tune will fix this but it there anything I can do to help it I was going to bring it to eastside but I am in NY seems like a long ride to take a chance .
Oh it is an FM-13 112 and it will idle ok
There shouldn't be any fuel in your oil regardless of the cam you're running. You've gotta ask yourself how the fuel got mixed with the oil. There is only one way the fuel goes into the cylinders and that's through the intake ports. In order for fuel to get into the oil, there has got to be something wrong in the cylinders. You should also not lose oil pressure after a simple cam swap unless you changed the oil pump and something went awry there. Is the valvetrain pretty noisy?
Originally Posted by TOS98SS
I just did my cam swap with 01 heads and it is running pig rich ....
The loss of oil pressure is because of the gas in the oil. Gas makes oil very thin. If the engine is running VERY rich depending on how long you ran it the cylinders were probably washed down with gas and that would allow gas to get in the oil. Does it have any codes like maybe the map or the coolant sensor? If one of those sensors would not be hooked up or even bad it would run rich as hell.
Originally Posted by ArcticZ28
Was the intake comment a separate thought unrelated to this?
my bad, I don't know what I was trying to say there. but, you very well could have washed down your cylinders and then you can have some gas slip through.
Yes this is the problem I let the car idle to check an exhust leak then . And when the car stalls the engine is flooded so I am sure that is how the fuel is getting in the oil . I don't have any codes just thought it wiould be running a bit leaner not pig rich you know
