Help please!!!
Old Oct 2, 2006 | 01:42 PM
SSpdDmon's Avatar
Default Help please!!!
Ok, I've got my friend's '99 SS (Patriot Stg II LS6 heads/Torquer V.2 cam/supporting bolt-ons) dialed in pretty good on AFR (12.3@peak_tq~12.8@peak_hp) and timing (25*@peak_tq~29*@peak_hp). Only have a little burst knock issue to work out. However, it doesn't seem to be making the power it should be...or at least running the times it should be. At the track, he only trapped a best of 110mph with a best ET of 12.34. This was on DR's with 1.7 60' times at roughly 900' above sea level. The air was in the 60's~70's and virtually perfect. And on the dyno a while back, it only put down ~380rwhp with the converter locked up. What gives? I've been through almost every table in this tune and can't find what's holding him back.
The only thing I can think of is it's got to be mechanically related. The car is still running the stock 3.23's with a 3500 TCI converter and probably weighs in at 3700lbs with the driver. It leaves the line like a bat outta hell, 7.8's in the 1/8th, but seems to fall on it's face the 2nd half of the track. It does spend a bit of time in 2nd. I don't think he hits 3rd until just before the 1000' mark.
Another thing that's kind of odd is my other friend's '00 T/A (vert) has the same cam with stock heads and runs the same time. I feel like I'm missing something, but can't figure it out. Any ideas would be highly appreciated!!!
Old Oct 2, 2006 | 01:43 PM
dnm12's Avatar
no heads and look at my dyno's
Old Oct 2, 2006 | 03:24 PM
SSpdDmon's Avatar
Granted dynos are purely tuning tools and numbers can be skewed...but I'm sure there's something missing here. My car ('02 Z) on a stock cam with mods in sig below went 12.50's at the same track. Its hard to convice myself a car with the same weight plus LS6 heads and 232/234 .595/.598 cam will only run 2-tenths faster.
Old Oct 2, 2006 | 08:16 PM
SSpdDmon's Avatar
Nobody?
Old Oct 2, 2006 | 08:20 PM
ArrestMeRed99Z28's Avatar
are you sure that the cam was degreed properly?
Old Oct 3, 2006 | 08:08 AM
SSpdDmon's Avatar
Both cars had the cam installed dot-to-dot. Doesn't this achieve the same goal?
Old Oct 3, 2006 | 09:27 AM
SSpdDmon's Avatar
Nevermind my last response. I read up on degreeing and found some useful info here (http://www.gmhightechperformance.com...ee_an_ls1_cam/). No, the cams were not degreed.
Is this the most logical reason for the issues I described in my original post? Why else would a cam-only car and a h/c car make the same hp?
Old Oct 3, 2006 | 01:13 PM
SSpdDmon's Avatar
Will bribe with beer for answers!!! (pickup only)
