Sewing Machine????
The motor is a standard bore with a 3.900 stroke (eagle rods and pistons, JE pistons) CnC ported LS6 heads. Comp cam kit (224/230@.050 .581/.588 114*)
lifters and pushrods. Scorpion Rockers. Supermaxx headers and a SLP LM2.
The machinist used 7.400 pushrods when he put the motor together. I science put in some 7.425 to see if it would quiet it up. Its better but not satisfactory.
Ive let people listen to it and I get responces that its normal , bent pushrods and one guy told me that Comp had some problems with their lifters.
Im taking the car in to Speed Inc. Fri for a dyno tune. hopefully they will have an answer.
What should I do? Anyone find a cure for this? At this point I dont care how much it costs.
Its embarassing bragging to your friends all summer long about your badass car your building and put 15,000.00 in and when I show it off they ask why it sounds like **** and have that goofy look on their face.
Thanks for any help in this matter.
Greg
P.S.
Its not an exhaust leak.
I'm running a 233/239 .595/.603 and mine does it all the time. It's just something you deal with when running cams with aggressive lobes. Kind of like changing the valve springs every 15-20k.
I have a 232/234 XE-R and no noise at all. I played with mill and gasket to reach proper preload on the p-rods I wanted to run.
i'm running 7.400 and my heads are milled .025' and gasket is .050.
You can actualy hear the injectors pulsing
My sewing machine sound is only below 1200 rpm though.SSDION
You kids, I swear! Why, back in the day, a rumpy dump idle and noisy valvetrain was a thing of beauty. Meant you were da **** and challenger beware. I love the sound. And those that know cars recognize that sound.
Come on fellas! Be proud of what you have.......and quit bitching like little high school girls on the rag.
J/K The simple approach I think is to carefully check your preload. If 7.425s made it better it's probably a good bet that your preload is wrong. Get it between .060 and .100 and I think you'll see a big difference.
J/K
J/K
