can't get damper off!! Testing my temper!
Old Oct 9, 2006 | 11:27 PM
mvvette97's Avatar
Default can't get damper off!! Testing my temper!
Ok, I have a 3 arm puller but that damn thing is tightas hell. First of all do the puller arms hook on the three tabs that is near the center of the damper or should I be pulling on the back side of the damper? Are they always a bitch to get off?
Old Oct 10, 2006 | 12:12 AM
SLP4CamaroSS's Avatar
i just put mine on the 3 tabs from the center and it came right off
Old Oct 10, 2006 | 12:14 AM
DarinsTA's Avatar
they hook on the 3 tabs. i use a "chrysler balancer puller" but I use a longer bolt out of one of my other pullers. This works very well. You can get a "loan a tool" from autozone. good luck
Old Oct 10, 2006 | 12:16 AM
ArcticZ28's Avatar
You can pull from either area, and yes the stock crank can be a pain in the *** if it's been on there a while.
Old Oct 10, 2006 | 12:22 AM
mvvette97's Avatar
I read that you can use a little handheld torch to warm up the damper a little to help it come off. Do you think that will hurt anything? I was thinking about having pressure on it from the puller and putting a little heat to the center of the damper.
Old Oct 10, 2006 | 12:56 AM
ArcticZ28's Avatar
Some people put some heat on it if they really can't get it off but be careful not to heat it too much as you could warp the crank.
Old Oct 10, 2006 | 09:05 AM
V6 Bird's Avatar
Yes, you can heat the pulley itself around the spokes to help it release...just be careful with the heat...
And as for these people saying you can warp the crank.....answer me this. Has anyone done that yet?
Be sure and replace the crank seal if you do use some heat to help get it off. It may leak if you dont.
Old Oct 10, 2006 | 09:24 AM
99C5JA's Avatar
Yup it's a b*tch. Use as big a wrench as you can and just keep cranking. Everytime I remove the rack and work with the pulley I swear it's the last time. Somehow it never is
Old Oct 10, 2006 | 10:41 AM
mvvette97's Avatar
Yea, I said last night that I will never do it again
Old Oct 10, 2006 | 03:34 PM
charlie c5's Avatar
As wierd as it sounds, go to your local autozone or Hi-Lo and rent their Chrysler crank pulley puller. It works great on the LS1.....
Old Oct 10, 2006 | 03:44 PM
8banger's Avatar
Mine was never that bad...I just got the puller and crank at it. A good breaker bar works wonders. Getting it off is a bitch though.
Old Oct 10, 2006 | 08:14 PM
Charlie@LsXperts's Avatar
dont heat it up cause your gonna burn yourself when it falls
Old Oct 10, 2006 | 08:36 PM
1320 killer's Avatar
Mine was a real bitch to get off. I used the puller and a 1/2 inch dr. breaker bar plus a cheater bar that was about 4 ft. long.
Old Oct 10, 2006 | 09:33 PM
1stz06's Avatar
Charlie is absolutely correct. Get you a Chrysler puller from Autozone and use a longer bolt. Works like a champ. Good luck!!
Old Oct 11, 2006 | 07:38 AM
Steve Bryant's Avatar
LS1 Tech Veteran
myvette97,
Try greasing the threads of the puller and put some grease on the end of the puller bolt where it rotates against the crank snout. Another thing to try is spraying some WD-40 around the crank snout (front and back of the pulley) about three times (once every hour or so for three hours). Maybe the penetrating action as well as the lubricating action will help.
I've had my pulley off three times. The first time it was really hard to break loose . . . took me about four to six hours. The next two times, it was a breeze. I'll be doing it again within the year once I get my 408 built. The first time is the hardest.
All my best,
Steve
Old Oct 11, 2006 | 08:28 AM
charlie c5's Avatar
Did you get it off yet????
Old Oct 11, 2006 | 12:06 PM
8banger's Avatar
I didn't see what tranny you had...if it's an A4 you can always lock the flywheel
