222/224 comp cam
Old 10-13-2006, 08:56 PM
zain98's Avatar
Default 222/224 comp cam
What do you guys think about a 222/224 581I 581E XE-R 113+0
Good DCR with an all stock ls6 motor? Like stock gas milage with your foot removed?
Will this cam idle like stock or lope alittle?
Old 10-13-2006, 09:04 PM
66deuce's Avatar
it will definately lope.i have the cam in my sig,and with the idle at 725 rpms,it lopes a little bit.that is a slightly bigger cam on a 113 lsa,so you won't mistake it for stock.
should make a good street cam with a broad powerband.
Old 10-14-2006, 05:39 AM
macca33's Avatar
I've got the Comp 222/224 @ 112 0.566/0.568 in my car. It lopes very nicely and makes good power right thru the rev range.
You will enjoy the cam you have specified.
Cheers,
Macca
Old 10-14-2006, 10:01 AM
zain98's Avatar
What about gas mileage?
Old 10-14-2006, 10:03 AM
mattraypharbor's Avatar
i have allot biger cam than that and im seing allmost the same gas miliage with a lite foot just dont get into it and u will be suprsised...
Old 10-14-2006, 12:07 PM
vettenuts's Avatar
Do you have the intake centerline and overlap of this cam?
Old 10-14-2006, 12:42 PM
zain98's Avatar
No i dont
Old 10-14-2006, 12:59 PM
dnm12's Avatar
check cam sig there is photos on page 6 of my website and there is also the videos below for an idea of lobe and the dyno for an idea of power keep in mind these are the poopy flowing 98 heads
Old 10-14-2006, 01:01 PM
YankeeVert.'s Avatar
overlap = (222-224)/2 - 2* 113=223-226 = -3
ICL=LSA-advance=113-0=113
Old 10-14-2006, 07:37 PM
zain98's Avatar
thanks
Quick Reply: 222/224 comp cam
