317 6.0 heads
Old Oct 21, 2006 | 06:20 PM
trans2000am's Avatar
Default 317 6.0 heads
just got some 6.0 heads what size pushrods do i need, can i use aftermarket springs,seals,retainers from stock ls1 heads?
Old Oct 21, 2006 | 07:28 PM
bump ttt
Old Oct 21, 2006 | 10:49 PM
muncie21's Avatar
The 317 (6.0L) heads are very similar to the 243 heads. Pushrods and valvetrain components are interchangable. Most truck heads, including the 317, will come with integrated valve seals and spring seats. So don't go buying a set of seal only, valve seals.
Old Oct 22, 2006 | 02:16 AM
prostock_bigblock's Avatar
I am not sure but I think they r 7.425, I will check that out and post it later.
Old Oct 22, 2006 | 11:42 AM
thanks guys
Old Oct 22, 2006 | 01:11 PM
GuitsBoy's Avatar
What cam are you running? A stock cam would need stock length pushrods. While you can use a 7.4 pushrod on a 1.450 base circle cam, a 7.425 will quiet things down by giving you closer to stock lifter preload. The geometry should be identical to any of the ls1 / ls2 / ls6 heads.
Old Oct 22, 2006 | 01:23 PM
cam is gt-7 for force induction
Old Oct 22, 2006 | 02:01 PM
muncie21's Avatar
Is the car up and running? I was looking at the GT-7 and the GT2-3 cams. Wondering how you like the cam, if you've had a chance to run it yet.
Old Oct 22, 2006 | 02:13 PM
no not yet havent started install waiting for more parts.ive heard the cam is great for force induction.
Old Oct 22, 2006 | 07:39 PM
bump ttt
Old Oct 23, 2006 | 01:22 PM
MiaSSmaro98's Avatar
really wanna know i bought stock size push rods but im getting my block rebuilt and heads rebuilt as well so im guessing with the material removed i should be fined
