Engine rebuild
Old Oct 26, 2006 | 11:14 AM
99camarosupersport's Avatar
to the top..
Old Oct 26, 2006 | 11:20 AM
Cop Car's Avatar
lurk around in the LS2/7 section, lots of info on the LQ4s, L92s etc
Old Oct 26, 2006 | 11:57 AM
Thanks cop car, i'm sure you'll be seeing plenty of post from me in the near future on this subject! Thanks!
Old Oct 26, 2006 | 08:48 PM
Im also considering keeping stock cubes but staying with the idea of being forged, for forced induction later down the road.
Old Oct 26, 2006 | 09:48 PM
BlackHawk T/A's Avatar
Building an all iron motor doesn't make much sense unless you are shooting for 1000+hp. Then if you do, what transmission/drivetrain setup is going to handle that? Not worth the 100+ extra lbs on your front end IMO. I have never seen anyone report an aluminum block related failure.
Old Oct 27, 2006 | 02:02 AM
I'd prefer keeping the alum. block, i know cop car hates it and thinks it's dumb but it's just a personal preference, although i'm very open to the 402. I'm considering staying with the 347 and simply rebuilding and forging that...how much cash would i be looking at doing that VS. a 402, also i'm considering the stock CI because i'm not wanting ot have to go buy a bigger cam and new heads, and i'd like to set the car up for forced induction on forging the stock cid.
Old Jan 15, 2007 | 09:11 PM
the.erinyes's Avatar
If you use aluminum, just use an engine girdle and you can take to 1,000+ horsepower - no problem!
Old Jan 15, 2007 | 10:43 PM
Cop Car's Avatar
its 70lbs. get a tubular K member, weight solved.
Old Jan 16, 2007 | 05:39 AM
AmericanMuscle313's Avatar
Wow this post is old but I want to add my experience building a 408. I think a 383 would meet your goals but let me share what I have learned.
I came across a good deal on a lq4 block that needed to be rebuilt. I started getting into the "well Im already rebuilding it I might as well...." and it ended up costing me. I originally planned on spending about 3500 and it has cost me twice that. Dont get me wrong I now have a badass 408 with forged crank, rods, pistons, AFR 225 heads, etc but if I had to do it over again I would have saved money and just done a basic rebuild with forged pistons (maybe rods too) and a good set of heads.
If you do a 402/408 you have to factor in all the supporting mods like making sure your rear end and flywheel/clutch/tranny will hold up. It looks like you have a nice bolt and cam setup right now and you will be able to re use a lot of those parts if you go with a forged 347/383. If you go forced induction you will want a lower static compression ratio.
If I were you I would do a 383 with an eagle crank, compstar forged rods and some Wiseco nitrous pistons. If you are not satisfied with your numbers you can always add a healthy dose of nitrous. Option 2 would be to re use your crank and put that $900 towards porting your heads. and doing a forged 347.
Did you already make a decision since this first posted?
