Cam Guru's Help For 383
So I have a brand new Magic stick 4 that i was going to put in my 346 but have since decided to go with a forged 383. Knowing that the extra cubes will "soak up" alot of the cam. What cam duration and lift #'s would approximately match my MS4's radical idle,powerband,etc in a 383? In other words please give me some cam specs to go by that will both still sound nasty in a 383 and give big power while acting like a MS4 in a 346 < if that makes any sense
I will be using PRC LS6 stage 2.5 heads and the engine should come in at 11:1 compression. Predator?, Patrick G ? Others? Thanks for any input! its custom grind time I'm sure.
I will be using PRC LS6 stage 2.5 heads and the engine should come in at 11:1 compression. Predator?, Patrick G ? Others? Thanks for any input! its custom grind time I'm sure. Seems to me there was a similiar question posed in here recently, but my short term memory has been acting up so I'll root around some BUT I THINK it was said that for every 50 cubes you should/can add 10 degrees duration to said cam spec.
Here ya go.........similiar but not exactly the same.....
https://ls1tech.com/forums/generation-iii-internal-engine/597530-228-232-346-what-402-a.html
We have our TX Giant that you could throw in your 383. Its a 248/254, .622"/.614" on a 112LSA. You'll definitely know it's there. It would make some good power and have plenty of lope to it. We sell quite a few of these with our 402/408 motors. I have sold a couple of these to guys with 383s as well.
Brian
Brian
__________________
01 NBM Z28- A4 w/3.23s, TSP Black Lid, Hooker Catback, Pacesetter Headers w/ORY, ASP Pulley, Ported Throttle Body, TSP Torq. v3(231/234) Camshaft, TCI 4400, PRC Stg 1 Heads
Texas Speed & Performance
www.texas-speed.com
(806) 866-0734
www.texas-speed.com
(806) 866-0734
Brian
Brian
Originally Posted by PREDATOR-Z
I would stick the stick4 in
plenty of good cam there.
So i figure my car with PRC LS6 stage 2.5's with a 383 and just as good of suspension set-up should make him a bit nervous!
Hey Predator, In all this time on the boards I JUST NOW noticed that you live in DUBAI ? WHOLLY HECK MAN! You are NOT just around the corner my friend. Were you born there? If I'm not meddling to much what is your life situation ie: how did you end up there if you are not a natural born citizen? I here it is a BEAUTIFUL and very well maintained country!
I'm a US citizen, originaly from TX, product of 1/2 breed society
We can swap it out for you. The intake uses the XE-R lobes but the exhaust is not. If you decide to switch, just send it back and we'll get the Giant out to you.
Brian
Brian
__________________
www.texas-speed.com
(806) 866-0734
www.texas-speed.com
(806) 866-0734
Brian
Brian
Now that WOULD have to go on a 408! Wait...with that much duration AND lift what would that cam even act like? it would be wierd having all that duration AND lift! Last edited by DogNutz; Oct 26, 2006 at 03:06 PM.
