thinkin 110 might be to low
Old Oct 24, 2006 | 04:41 PM
transamfreak01's Avatar
Default thinkin 110 might be to low
so i was going to go with my ms4 with a 110 lsa but now im thinking since i have a 3600, would i be better off gettin a 112 lsa or higher b/c doesnt your powerband start earlier with a lower lsa??? i just thought id have uselss power. tell me if im wrong
Old Oct 24, 2006 | 05:01 PM
KingSS's Avatar
Go with the 111LSA. When TSP engine dynoed the ms4 they found the 111LSA had the best power in the best places. That should provide for a pretty monster setup once tuned.
Old Oct 24, 2006 | 09:06 PM
yeah but i was thinkin with a 3600 converter wouldnt the start of my power band be useless b/c would it start before 3600???
Old Oct 24, 2006 | 09:33 PM
JakeFusion's Avatar
Super Hulk Smash
I'd say 3600 is a low stall for the MS4 even at 110. It'd perform better with a 4000 or 4400 stall if you want the best possible ET. The 3600 will work, though, but ideal would be an MS4 111 LSA with a 4400 stall.
As for as not working, the MS4 is not going to make a ton of power before 3k, so any stall bigger than 3k will work well enough with it. But, the torque will peak at 4800 (like all cams because of the intake manifold runner restriction), and you want to be close to that (400 rpms before, so 4400 stall), and have a cam that makes power from 5000-7000 to run a really good ET.
If ET doesn't matter, run the 3600. It'll be more streetable.
Old Oct 24, 2006 | 09:36 PM
rickyracer25's Avatar
You also have to consider when you are going to shift. Sure you can start the powerband later but that is going to push the peak further up in the rpm band. (push it too high and you'll never see the peak.
Old Oct 25, 2006 | 04:45 AM
magius231's Avatar
also: the MS4 on a 110 is a PTV dance event waiting to happen. be prepared to flycut your pistons if thats what you go with.
Old Oct 25, 2006 | 05:33 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I was gonna say. You will most likely need reliefs with that kind of grind.
Old Oct 25, 2006 | 10:00 AM
yeah i think i am going with a 111 lsa and the reason for the 3600 is b/c its more of a street car and wont see much track time.
Old Oct 25, 2006 | 10:02 AM
oh and does a 111lsa require flycutting???
Old Oct 25, 2006 | 02:02 PM
Ryan02SS's Avatar
Good Info here...
http://www.compcams.com/Community/Ar...ID=-2026144213
