Again. Help with DCR please.
Old Oct 26, 2006 | 11:38 AM
jebcamaro's Avatar
Default Again. Help with DCR please.
I have been trying to figure out my DCR for my new setup. I downloaded the calculator, but I can`t get it to let me put any values in it. So would someone please help me. Stock 01 LS1. Ported and milled .018 853`s, .042 head gasket and comp cam 228 cam. Here`s the cam card for the cam.
File Type: pdf
Old Oct 26, 2006 | 09:15 PM
jebcamaro's Avatar
thanks for the overwhelming responses
Old Oct 26, 2006 | 09:29 PM
jebcamaro's Avatar
piano prodigy lookup
Old Oct 26, 2006 | 09:30 PM
pist0lpete's Avatar
Which calculator did you download?
Old Oct 26, 2006 | 10:10 PM
Gannet's Avatar
If you have the combustion chamber CCs I'll put it in the calculator for you.
Old Oct 27, 2006 | 01:54 AM
jebcamaro's Avatar
whatever .018" from the stock cc size of a 853 head is. I don`t know
Old Oct 27, 2006 | 01:48 PM
jebcamaro's Avatar
CC size for my cylinder heads are 63.67
Old Oct 27, 2006 | 04:06 PM
Gannet's Avatar
I am as far form an expert on this as you can get, so take this fwiw.
The cam card was a little hard to make out, but it appears to be a 228/228 with #3718 lobes, ground on a 113 LSA and installed 2 degrees advanced, for a 111 ICL.
Assuming a stock LS-1 shortblock, .042 gasket, and 63.67cc heads, my calculations yield a SCR of 11.017 and a DCR of 8.280. The IVC is 45 ABDC (@ 0.050).
Installing with 4 degrees of advance (109 ICL) boosts the DCR to 8.428 and pulls the IVC back to 43 ABDC.
Old Oct 27, 2006 | 04:28 PM
oange ss's Avatar
yes....
Old Oct 27, 2006 | 04:29 PM
jebcamaro's Avatar
Yes, your assumptions are correct. Thank you very much. I assume that is a safe DCR to run on the street with 93 octane gas, right?
Old Oct 27, 2006 | 04:35 PM
Gannet's Avatar
Yes. Based on what I've read in other threads, the safe upper limit for 93 is around 8.8.
8.28 is a solid boost over the stocker's 7.07.
Old Oct 27, 2006 | 04:54 PM
jebcamaro's Avatar
Good, maybe that will keep me well within the safe limits to possibly run nitrous in the future
