408 guys, what CR are you runing?
Old 10-30-2006, 08:11 PM
Rhino79's Avatar
Originally Posted by whitt1
How high do want to rev your 408?I don't normally take mine past 6600rpm.The wall you are hitting may not be caused by your intake.Are your heads porting stock and what valvesprings are you running?
Ported heads and PRC Dual Springs, cam is 233/239 .595/.603 113LSA. Power is just flaat past 5600 till 6200 or so and then drops off. I think the motor just needs more air than the truck style can provide in the upper rpms.
Old 10-30-2006, 08:18 PM
nastyta's Avatar
I got a callie crank and compstar rods mahle pistons arp everything plan on spraying 180 shot plate system nx, building a 408 i would recomend trying to get away from ne thing stock if u plan on spraying.....im running 255l wal. full racetronix fuel sys. with 42lbs svo's
Old 10-30-2006, 08:29 PM
10 Second Fun Car
jlrz28's Avatar
Anyone ever tried to run a 408 on 8-9.5:1? How much power is normally left on the table that could be had from 10+? Not trying to hijack but just though it would be nice to run on cheap stuff or medium stuff.
Old 10-30-2006, 08:57 PM
Lurius's Avatar
Been kinda wondering this myself. If i only lost like 50hp from going to 8.5:1 or 9:1 vs 10:1 then i would go that route, leave it open to FI later on.
-Lurius
PS: I looked at eagles site, and they have a prebalanced 408 kit with je pistons for 2600$ on jegs.com Might go that route.
Old 11-22-2006, 03:36 PM
Cam02ss's Avatar
I'm basically wondering the same thing. Texas speed is sending me a couple 408 estimates and are telling me if i'm going to spray a 200 shot then i don't want anymore than 11:3 compression. Thunder Racing on the other hand is telling me no more than 9:5 or 10:1.
You guys running the 12:1 compressin,etc. How is it on the street? I believe one of you said you are running pump gas with it? Is that the usual case with that high of a compression? Thanks
Old 11-22-2006, 04:46 PM
slow trap's Avatar
when i finally get the motor in i plan on spraying my 11:7 cr 408 on pump gas.the dcr is what you need to worry about more than scr.
Old 11-23-2006, 01:24 AM
2c5s's Avatar
11.2 -13 pistons, .008, .041 and 62 chambers
Old 11-23-2006, 08:03 AM
1FST99Z's Avatar
JE pistons 9.5:1 preparing for a supercharger.
Old 11-23-2006, 08:05 AM
Race your car!
JL ws-6's Avatar
Well I'm not running a 408, but I am running an alum 402. 12.8 to 1 compression, and it runs on 105 unleaded. I do plan on spraying it, I will start off with a 125 hit, but I'm sure it will be 2 stages of that much before I'm thru.
Old 11-23-2006, 08:14 AM
ls1408cp's Avatar
my 408 is 12:1 I run only pump gas but I have a big cam to bleed off pressure
Old 11-23-2006, 11:12 AM
b727pic's Avatar
JE FSR -29CC, Dart 225's, .040 Gasket, Zero Decked.
Old 11-23-2006, 11:17 AM
  #32
oct03gto's Avatar
How about RWHP numbers? I am in the process of buying parts for my 408 build up. Iron block, and forged internals. Staing around 11.0:1 to 11.5:1. Will be running ETP 240 heads. I think I will gernade my six speed for this one.
Quick Reply: 408 guys, what CR are you runing?
