Comp XR or XER
Old Oct 31, 2006 | 11:48 AM
LSX-Racer's Avatar
Banned - Ed Curtis aka EDC
Originally Posted by PREDATOR-Z
Their cams are Comp cams and their Gold springs are top notch. The reverse 230 cam they have is not so good, but the 226 is great.
I don't believe Patriot ever used Comp Cams for their grinds. Originally it was Reed but I believe they now go elsewhere.
Old Oct 31, 2006 | 12:00 PM
KurtRardin's Avatar
Veteran: Marine Corps
That does sound like a good cam. I think I might seriously go with something like that. When i get the time/money I might have one carved up like that. What spring/pushrod setup would you go with?
Old Oct 31, 2006 | 01:01 PM
Billdog350's Avatar
If you are looking for a good cam only with good midrange till 6500 rpm, this is what I would recommend: 228/232, .588/.595 110+4 (Comp XE-R) custom grind.
I have this exact cam going in later this week. I'll be able to post results with a set of new ported PRC LS6 heads, LS6 intake, LG Street lt's and z06 Ti's. Aiming for ~430-450 rwhp if all goes well after tuning.
Old Oct 31, 2006 | 02:19 PM
KurtRardin's Avatar
Sweet, who cut it up for you? Im very interested in seeing your results!
Old Oct 31, 2006 | 02:45 PM
KurtRardin's Avatar
PREDATOR-Z, how would the Vinci 049 cam 228/232 .600 /.600 OVERLAP 68*
LSA 112* Compare to the cam that you recommended (228/232, .588/.595 110+4 (Comp XE-R) custom grind)? I know it uses a different lobe and the LSA is different, but this cam would work with my VHP tuner. I think i posted a thread about this cam a while ago, but im not sure if you replied to it or not. Id like your input on this cam for me. Its extra appealing to me because its designed to work with my tuner.
Old Oct 31, 2006 | 02:47 PM
bluehawk2's Avatar
I Don't have a very good knowledge of many of the different cams out there. I am still fairly new to most of this. However I have a Comp 232/236 595/601 on a 112+2 XE-R in my car. I have had it in for about 7,000 miles. I really like the cam so far. It is very streetable. My car is a DD. The Idle quality is good. I think it would be better if I had a better tuner working on it. My car made 410 RWHP and 390 torque on a dynojet. I will have to wait and see how long my patriot dual valve springs last with this cam.
Old Oct 31, 2006 | 03:18 PM
ArrestMeRed99Z28's Avatar
Is this cam only? If not what kind of heads are you running? What's your intake and exhaust set up? What kind of a dyno were you on?
Thanks
AJ
Old Oct 31, 2006 | 03:47 PM
bluehawk2's Avatar
I have a 02 Firehawk with a lid k&n filter, underdrive pulley and a TCI SSF 3500, LT's and ory, stock ls6 intake. At the time I dyno'd I had stock heads. Now I have ported ls6 heads with stock valves. I dyno'd on a dynojet this summer.
Old Oct 31, 2006 | 03:50 PM
bluehawk2's Avatar
I am saving money to have a different person tune my car for the heads. The last tune I got made good power on the dyno, but he didn't do much for the issues with the torque converter and the idle was not good after the tune. I had to have a friend of mine help me work out the idling problems.
Old Oct 31, 2006 | 06:47 PM
tboysen00's Avatar
so you dont like patriot reverse 230 or the comp 230. i thought you told me to keep that came on my thread. just making sure. thanks troy
Old Oct 31, 2006 | 07:30 PM
My90Iroc's Avatar
I have the 232/234 XER cam on a 112+4 grind and I love it. I don't daily drive it but I certainly could. I run the patriot gold double springs and they do the trick. I don't know how many miles you drive a year but I don't see why at least 10-15k would be a problem. After that I'd check the springs every so often and see how they're doing. Here's the thread with my dyno numbers.
https://ls1tech.com/forums/dynamometer-results-comparisons/592430-2000-ws6-h-c-i-numbers.html
Old Nov 1, 2006 | 09:39 AM
  #32
Billdog350's Avatar
I believe its coming straight from Comp. Not sure on the lobes, it was spec'd by Slowhawk for my specific application.
  #33
KurtRardin's Avatar
Isnt it nice to have people who have used many cams, and actually know what they're talking about when they recommend a custom grind? I never would have thought about something like 110+4 LSA. Havent seen it offered on the shelf, so didnt think to ask. I hope that your cam does good. When I get the $ I plan on having one carved up and shoving it into mine.
Old Nov 1, 2006 | 08:49 PM
  #34
wilddawg's Avatar
I have a 220/222 comp XER that works great it does have the ticking sound I wish I had known about the pushrods to quiet things down I have 20K on 918 springs and I have checked them at l0k both time and they still checked out good
Old Nov 2, 2006 | 05:02 AM
  #35
BlackHawk T/A's Avatar
what does the +2 mean on someones signiture? Do you still use the dot to dot method of install or does the +2 mean something different?
Does a 112+2 basically make it a 110?
If so then why not just get it on a 110?
Old Nov 2, 2006 | 07:19 AM
  #36
LSX-Racer's Avatar
Timing events that result in a tight LSA are not new. Maybe to this site, but not to most hardcore LS1 racers. The Auzzies have been doing it for years too.
Old Nov 2, 2006 | 07:28 AM
  #37
PREDATOR-Z's Avatar
yeah but most Aussies tune SD (MAF-LESS).
Also our intake design is part of the idle problems we face. Slip on a ITB setup and hear a 24x cam on a 106 LSA. Purrs like a 224
Old Nov 2, 2006 | 09:05 AM
  #38
GuitsBoy's Avatar
No, the +2 advances the whole cam (from straight up). The angle between the intake and exhaust lobes would still be 112 if both were advanced or retarded equally.
Old Nov 5, 2006 | 12:19 PM
  #39
stone4779's Avatar
I have looked and looked for dyno numbers for the 226 cam and i cant fint squat! Mvvette97, have you dynod your car or do you know what kind of numbers your cam is suppost to make? The V2 is almost garunteed to make over 400rwhp with all bolt ons.
Stone4779, do you have any clips of your car idling or driving? Id love to hear it. I really like what you have been saying about it!
I uploaded a short idle/rev clip the other day...
https://ls1tech.com/forums/multimedia-exchange/602926-clip-my-cammed-z28-idle-rev.html
Not much, but it's something...
Old Nov 5, 2006 | 01:14 PM
  #40
nseldy's Avatar
Hey does anybody have a sound clip of the XER lobe 228/232 .588/.595 110+4? I'm thinking this is the cam I'm going with, but I was curious how it sounded?
Thanks
By Brett Foote | 2026-06-04 05:00:17
