Comp XR or XER
Old Nov 5, 2006 | 08:59 PM
  #41
stone4779's Avatar
btw I also just added a vid of the cam cranking....
http://www.youtube.com/watch?v=S0ZfsUXPzwY
and my GF shot a WOT vid at the track(crappy run though..)
http://www.youtube.com/watch?v=3xOIlclm5zw
Will add more as I get the time...or a video camera
Old Nov 26, 2006 | 04:52 PM
  #42
KurtRardin's Avatar
Veteran: Marine Corps
Well, ive got the time and the money to do a cam swap now, but now Im torn on what cam to get. Id like to do this swap as cheaply as I can, so i think i want to stay with the TSP 918 cam kit instead of the PRC Dual, plus this is my first cam swap. I think the V2 would be pushing it on 918s, especially since i drive at least 15k per year, even though TSP will sell the $599 kit with a V2.
Perhaps the 228R on a 112 would be best for me? Or another...??
I drive my car about 2 miles to school each day, so the warm up thing is going to be annoying. Im going to tune it with a local dynojet and my VHP Tuner with a 6800 rev limiter. An LS6 intake, and 4.10s will be going with this swap as well, and Im running a BorlaMouth/TSP Catted Y set up. If I knew the Custom cam that PREDATOR-Z recomended wouldnt be freakin expensive then i would absolutely love to go with that! If that is my perfect setup then I will just get that one....who could i call to do that cam...TSP??
Any help would be awesome!
Old Nov 27, 2006 | 06:33 AM
  #43
KurtRardin's Avatar
I think I am most happy with the cam that Predator-Z recomended for me, 228/232, .588/.595 110+4 (Comp XE-R) custom grind. It will work with my vinci programmer. Today Im going to find out who can make it for me.
Old Nov 27, 2006 | 08:32 AM
  #44
PREDATOR-Z's Avatar
TSP or Thunder can grind it for you.
TSP is $389.00
Also LS1 Speed (Speed inc) in Chicago area
Old Nov 27, 2006 | 09:19 AM
  #45
KurtRardin's Avatar
What Spring/pushrod setup would you recommend? Should I go with the 7.425 pushrods and 918s? Or something different. Im going to call TSP as soon as they open to get an idea on a few things since i have a lot to order at one time.
Old Nov 27, 2006 | 09:34 AM
  #46
PREDATOR-Z's Avatar
You can run 918's or TSP gold duals if you prefer.
If you choose 918's I recommend TSP's titanium retainers.
Cam only with unmilled heads and stock gaskets, you can run either 7.400 or 7.425's.
I prefer the 7.425's (Comp Cams)for less valvetrain noise.
Old Nov 27, 2006 | 10:36 AM
  #47
KurtRardin's Avatar
So from what I gather, with the 7.425 pushrods all i have to do is reinstall the rockers to the stock 22 ft/lbs and my valve springs and everything else will be fine? Or once my 918s are on do i need to do something different with my rockers?
Old Nov 27, 2006 | 10:56 AM
  #48
PREDATOR-Z's Avatar
Install, trq to specs (22ftlbs), rotate 2 or 3 times the crank by hand and re-check trq specs. Just be careful to have the correct trq amount on the trq wrench.
Check this site for full info:
http://www.ls1howto.com
Old Nov 27, 2006 | 10:57 AM
  #49
KurtRardin's Avatar
Thanks man. You've been a big help!
Old Nov 27, 2006 | 11:49 AM
  #50
KurtRardin's Avatar
I just talked to Zach at TSP and he said it all sounded good and they can have it ground whenever i want it. The only thing he said is that its probably going to be a bitch to get it tuned. I wonder if my VHP tuner will be up to the task. I know it does incremental percentage adjustments accross the board with the fuel and timing...i know it wont maximize my HP, but will it do?
Old Jan 23, 2007 | 10:43 AM
  #51
stone4779's Avatar
I've never used one, but I dont think it can do for you what a good tune will. You wont regret a real tune I can tell you that...
Old Jan 23, 2007 | 10:53 AM
  #52
KurtRardin's Avatar
Oh yeah, no doubt. But i see it getting me within 10hp of a real tune. If i use a wideband or a GM TECH II to monitor the o2 levels then i think i can get it close.
Old Jan 23, 2007 | 11:20 AM
  #53
stone4779's Avatar
Yeah you can get it pretty close though. It will start/idle a little rough though, but thats it.... It's not a terribly hard to tune cam...
Old Jan 23, 2007 | 11:43 AM
  #54
Spellbound's Avatar
Aside from spring life issues, what is the advantage of the Xer lobe over the XE lobe?
