Compression?
Old Nov 4, 2006 | 09:32 AM
TurboGoat's Avatar
Default Compression?
Whats the stock ls1 compression?
and if I add a set of 317 heads what will it drop the compression to?
thanks
Old Nov 4, 2006 | 09:35 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
So you want to drop it down...Those are the 6.0L heads aren't they?
Stock is 10.5:1 (That is static CR).
Are you planning on Forced Induction or something? If so you might want to drop your compression via pistons. Because if you need to drop it enough to crank the boost up.....bye-bye bottom end.
Old Nov 4, 2006 | 10:59 AM
GuitsBoy's Avatar
Stock is 10.5 on the LS6. The LS1 motor is 10.1:1. Some people have had amazing luck with stock bottom ends and low compression. A lot in the tune and how you beat on it.
Oh yeah, 6.0L heads should put you around 9.5:1
Old Nov 4, 2006 | 04:13 PM
chriswtx's Avatar
Yep, 6.0L heads will be right at 9.4-9.5:1...
