etp 265 heads
Old Nov 5, 2006 | 01:23 AM
hesham's Avatar
Default etp 265 heads
hi all
i just want to ask if i can install those heads can fit on my lq9 6.0 stock stroker engine or not?
Old Nov 5, 2006 | 04:19 PM
hesham's Avatar
any one can help
Old Nov 5, 2006 | 07:03 PM
Nate_Taufer's Avatar
Are you serious? TT and 300 shot? I don't believe it but here goes anyway. You'll need the Jesel Rocker setup on top of the heads and a custom intake, so you're looking at around 800 bucks for the Jesel setup and another 2500 for a nice sheet metal intake. Just go with their LS7 style heads and run an LS7 intake and save 3000 bucks. Should work nicely.
Nate
Old Nov 6, 2006 | 12:30 AM
SSilverSSurfer's Avatar
are you ******* serious?
Old Nov 6, 2006 | 12:35 AM
forgedbluess's Avatar
i want to see the first time you spray a 300 shot cause if im thinking right it should just crumble with twins.
Old Nov 6, 2006 | 12:41 AM
hesham's Avatar
please guys answer my q. about the heads and i will post pic as soon as i finish my car, but what about the heads they will fit or not?
Old Nov 6, 2006 | 01:22 AM
Asmodeus's Avatar
yes they'll fit.
Old Nov 6, 2006 | 01:24 AM
hesham's Avatar
thank you very much
i want to ask if they need special mods, rokers, gaskit?
Old Nov 6, 2006 | 01:28 AM
Is it a stock 6.0l block?
Old Nov 6, 2006 | 01:43 AM
hesham's Avatar
its lq9 bore 4.030" comp. ratio 8.3 : 1
cam lg x5g3 114
Old Nov 6, 2006 | 04:38 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
They will fit, but you are going to need a super sheet metal intake to get anything out of them.
Old Nov 6, 2006 | 05:14 AM
hesham's Avatar
i have fast 90 / 90 tb
and twin turbo isnt this enough?
Old Nov 6, 2006 | 06:26 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
No way. You might as well ditch that wet kit and improve your turbos. Get a water/meth setup.
Old Nov 6, 2006 | 06:49 AM
hesham's Avatar
i alrady have a boost cooler, but can you expl. please
Old Nov 6, 2006 | 07:20 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Explain what? A methanol injection system?
Old Nov 6, 2006 | 07:24 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
What is Water/Methanol Injection?
Water Injection or Water Methanol Injection, is a process by which a mixture or water and Methanol are injected into the fuel/air mixture on the way to the combustion chamber. Water/Methanol Injection provides "Chemical Intercooling" inside the cylinder. By injecting water and methanol in a finely atomized spray, the water is able to evaporate under the high temps of a firing cylinder, and when the water evaporates, it takes heat with it. The methanol also has a cooling and octane boosting effect as it burns.
How does water/methanol injection allow your engine to produce more power?
The production of more power by a water/meth injected engine is not a by-product of the water/meth mixture alone. You must tune for it to get the most out of it. The evaporative effects of the water/meth mixture, plus the octane boost, allows you to run more advanced timing, and boost, thus increasing power. Methanol having the octane boosting effect, you can adjust your AFR's with tuning, and be able to run leaner A/F ratio's than you would with just pump gas alone, with less risk of detonation, and also make more power.
How does that sound? But seriously. What kind of suspension do you have that is going to hold a 300 shot + Twin Hairdryers? there is no way you are going to get all that power to the ground without a back-half suspended car and a 31" slick.
Old Nov 6, 2006 | 08:05 AM
hesham's Avatar
thanks
Old Nov 6, 2006 | 08:49 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Seriously....How are you gonna drive that power?
Old Nov 6, 2006 | 01:40 PM
I also would like to know how your going to make a 300 shot work on this setup?
Old Nov 6, 2006 | 02:05 PM
Beast96Z's Avatar
They will fit, but, you will need the Jesel rocker system that is made for those specific heads. The rockers are $1400 by themselves. By the time you pay for the heads, rockers and upgrades, you'll spend $5k on that alone. Ask me how I know. Then, the FAST intake is almost worthless for these heads. You will need some sort of sheet metal or ITB like I got. For the bore your running, there's almost no reason for you to get the 265's. The added expense is rediculous when you compare the flow of the 255's to the flow of the small bore 265's. The best info has already been made. Buy ported LS7's and a ported LS7 intake and save massive amounts of money. If you have to keep your FAST intake, buy the 255's. I suggest you look at ET's site and compare flow between the 255's and 4" 265's.
