!Free Mods
-Free Ram-Air (!FRA)
-Fernco coupler mod (3"x3" or 3"x4")
-!Cutout
-Raise Air Box
-Ported Throtte Body
-Torque Trap
-Nostrils cut out on hood (Firebird only)
-Seal Air Box
-Bent metal lip down under air box
-Air Filter Screen / Panty Hose Mod
-Port MAF (!MAF)
-!MAF Screen
-Port & Polish Throttle Body
-Cut EGR (!EGR)
-Timing Tricker (!TT)
-Throttle Body coolant by-pass (!TB)
-!Thermostat
-Short belt (51 inches)
-Grind throttle stop to 4.6 volts
-!A/C belt
-Front tires at 45 psi (warm)
-Hollow Log
-!Collector mod
-!Muffler
-Knock Desensitizer Circuit
-!Air pump
-Fan switch
-!Bellows
-Ram Air Tubes
-!Silencers
Of course weight reduction...
Anything else out there ?
[ November 23, 2001: Message edited by: WILWAXU ]</p>
Thermostat
Where to put spacer in housing
How t-stat is assembled
example of spacer
where spacer is placed, assembled t-stat
a .090" spacer will give a ~170' temp, and I was thinking an 1/8-inch was ~160'.
Ryan
- I got those from TECH-LS1 by the way. This was originally Steve's thermostat modification.
[ November 13, 2001: Message edited by: RyanJackson ]</p>
[ November 14, 2001: Message edited by: MIGHTYMOUSE ]</p>
<strong>Tell me why you would take out your air pump??
Sean</strong><hr></blockquote>
Saves about 7lbs and cleans up the engine compartment quite bit.
Jason
<strong>What exactly does the "Hallow Log" mod do ?</strong><hr></blockquote>
From what I have seen it allows the stock exhaust manifold to flow better by gutting it.
Marty
Ryan
