the best cam
Old Nov 7, 2006 | 07:51 PM
red_stang_225's Avatar
Default the best cam
what is the best cam I can get it for full bult on 99 camaro ... ???
Old Nov 7, 2006 | 08:40 PM
NiCks Ws6's Avatar
lol.. newbie.. it all depends what you want.
Old Nov 7, 2006 | 09:01 PM
rickyracer25's Avatar
save yourself read the stickies at the top of the Internal section and delete this thread as soon as you can. In the stickies there is a part in there that they give you like ten really good LS1 cams. I won't feel sorry for you if you don't listen to me.
Old Nov 7, 2006 | 09:07 PM
Blue02Ws6's Avatar
It has to be a 278/291 .725 .812 101lsa That should give you some nice gains.... It is TOTALLY streetable too.
Old Nov 7, 2006 | 09:21 PM
um that would be why you want to delete this thread, although that would be great on the street and there would be power everywhere. lol
Old Nov 7, 2006 | 09:33 PM
03 BUSA's Avatar
sent pm
Old Nov 7, 2006 | 10:46 PM
mike#9's Avatar
I have 5 of those cams in my car right now. I pulls real hard at the track. Not as streetable as some other cams...but real easy to tune. I ran into a little bit of PTV clearance problems with my car (well originally I had 8 of those cams....) so I just pulled 3 of them out. That took care of that problem.
Here is the dyno graph
l
l
----------l--------------------------
l l
l l
l l
l l
l l
Sorry guys I just had too
Old Nov 7, 2006 | 11:13 PM
Blue02Ws6's Avatar
lol, well when you see the same question over and over and over and over...you get the idea, you just have to mix it up a little....
Old Nov 8, 2006 | 12:28 AM
pdd's Avatar
pdd
tough crowd
Old Nov 8, 2006 | 10:09 AM
bjamick's Avatar
l
l
l l
l l
l l
l l
l l
LOL thats funny as **** you can see where it hit VTEC!!!
Old Nov 8, 2006 | 10:12 AM
mattraypharbor's Avatar
Go BIG
Old Nov 8, 2006 | 10:15 AM
bjamick's Avatar
http://www.superchevy.com/technical/...in/0504sc_cam/
read this and maybe it will help you out and teach you some things about how engines work and how parts need to work with each other. that doesn't mean get a massive cam and then leave everything else stock. everything in the engine has to work together. so you get a HUGE cam that with a massive ex. and int. valve lift, so your letting all this air in but now your heads are slowing the flow of exaust out and your intake cant supply the air that the cam is calling for. so you've got to take into consideration everything.
