Do crank underdrive pullies hurt the durability of the engine over time?
I've asked this before (not on this board) but never really got good answer. I've asked a SAM school grad, he said it won't hurt IF the motor was properly balanced, however if the engine isn't well balanced over time it could.
The bottom line: Is the typical factory stock block LS1 or LS1 with heads and cam balanced well enough that a lighter underdrive pulley won't hurt the engine over the long haul?
I've been thinking ASP but I don't want to buy something that might tear the engine up.
Thanks
Thanks
LSX Mechanic
As long as your pulley in correctly installed, SEATED PROPERLY, and not damaged you should have no problems.
I ran a set of ASP pullies on my 98 for over 20K without one single problem.
Go for it!
Josh
Go for it!
Josh
