LS1 Oil Consumption
This topic has probably been discussed many times before but I was just wondering about your experience in the USA with excessive LS1 engine oil consumption. The topic is currently a hot issue between us Ozzies on the LS1 Holden/HSV forum & thought you might have more info such as:
1. Typical oil usage rates with synthetics such as Mobil 1?
2. Have GM come out with a fix other than the piston rings described in the article: "Beyond Awsome"?
3. Have many engines been repaired in the USA under warranty by GM to rectify the problem?
4. Any other words of wisdom?
Thanks <img src="images/icons/smile.gif" border="0">
check these links..
http://ls1info.com/article.php?sid=103
and another
http://ls1info.com/article.php?sid=5
I have heard that people using the synthetic
oils have more trouble with this.
According to an online survey of oil used
majority are running mobil1. I am from the
old school and dont understand synthetic oil.
Im sure it quite good, but I stick with dino
oil. For added proctection I have never let
the dino oil get dirty in 14K miles.
It's what i run and i use less than a quart in 2000 miles with many wide open throttle runs and higher rpm activity.
If this helps then try another synthetic like penzoil or royal purple, etc... 10w30 oil. I am sure there are other good oil filters but i recommend Mobil or delco oil filters as they are easily available and work well for everyone for our LS1 engines.
<strong>My motor does it no matter what...doesn't matter if its synthetic or non</strong><hr></blockquote>
It took some people a while to notice a difference. Like a few oil changes. Of course , maybe you now have some damage contributing to this, or had some to begin with. In any case, if i were expieriencing oil consumption i would not be pouring high dollar synthetic oil into it. I would try (in your case) penzoil(etc...) dino oil and change it every 2,000 miles and monitor it. Also use mobil or delco oil filters.
Have you done a leak down test on your cylinders to see if you have a definite mechanical problem?
Maybe your driving habits are contributing to this? You know, lots of high rev driving? Nitrous use?
Actully 1 quart every 1500 miles isn't all that bad. Some people have seen 1 quart every 500 miles. <img src="images/icons/shocked.gif" border="0"> So maybe (depending on your driving habits) you really don't have a problem. Or maybe it's PCV related(drawing oil in thru the PCV).
Have any of you noticed a significant reduction in oil usage after modifying the PCV system?
