Will cam make car run rich or lean?
Old Nov 18, 2001 | 06:01 PM
TheZman's Avatar
Default Will cam make car run rich or lean?
The FLP's made my car run very rich, I had to set the base on my MAFT to 10% lean. I am planning on installing either a HOTCAM or B1 this winter. Of course i will ATAP it after the install and readjust as needed, but i would like to know what i'm in for!
Old Nov 18, 2001 | 06:05 PM
BIGBOS's Avatar
Default Re: Will cam make car run rich or lean?
rich...not bad...but rich...
when you put a cam in it eats a little more gas..
Old Nov 18, 2001 | 07:05 PM
TheZman's Avatar
Thanks BIGBOS! why do so many people with an MAFT have it set on the RICH settings? Does a ported throttlebody, portedheads, ls6 intake, lean a car out?
Old Nov 18, 2001 | 09:46 PM
BIGBOS's Avatar
Probably because their cars werent used to the settings of all the new parts...and you have to make adjustments until the CPU learns it...it takes time to tune everything to how you want it..usually cleaning out the airway into the engine will lean the car out...
Old Nov 18, 2001 | 10:17 PM
TA_2001's Avatar
Rich at idle with a hotcam
Old Feb 7, 2002 | 10:17 AM
Bad Habit WS6's Avatar
belive it or not, my thunder cam leaned my car out. before the cam, i was running on the verge of rich, now im on the verge of lean by my gauge. <img src="graemlins/formula.gif" border="0" alt="[Pontiac]" />
Old Feb 7, 2002 | 11:40 AM
Scalpel's Avatar
[quote]Originally posted by TheZman:
<strong>Thanks BIGBOS! why do so many people with an MAFT have it set on the RICH settings? Does a ported throttlebody, portedheads, ls6 intake, lean a car out?</strong><hr></blockquote>
Read the info on this sight about MAFT and Intake modifications:
http://www.vetteguru.com
Great write up.
Old Feb 7, 2002 | 01:18 PM
gator's 99TA's Avatar
my cam with headers run PIG rich!
