Can I run nitrous and 4.10's???
Old Nov 18, 2001 | 07:41 PM
Big Mike's Avatar
Default Can I run nitrous and 4.10's???
Can I run nitrous and 4.10's or what?? I plan on going from my ET Drag 26x10x15 to ET Drag 28x10x15. I understand that will equate to a lower gear, but will that alone enable me to nitrous an 4.10's successfully?
Old Nov 18, 2001 | 08:00 PM
BIGBOS's Avatar
Default Re: Can I run nitrous and 4.10's???
I don't see why not...
You on a stock rear end...and do you plan on spraying right off the line??
If your a 6-speed you might have to make an extra shift at the end..into 5th
Old Nov 18, 2001 | 08:04 PM
Big Mike's Avatar
I'm running on a Moser 12Bolt so I'm not worrying about the rear. I plan on spraying off the line, but the whole thing is not having to shift into fifth. I should have phrased the question to "Can I run nitrous and 4.10's w/o having to shift fifth".
Old Nov 18, 2001 | 08:31 PM
ChrisB's Avatar
What size shot, and what kind of trap speed are your runnign without it, what is your rev limiter, and what tire type/size?
Chris
Old Nov 18, 2001 | 08:34 PM
Big Mike's Avatar
I'd like to do a 100 shot, the rev limiter is set at 7,000, don't know the trap speed because I will be going with a new motor setup, probably just heads and cam again and 28" tire.
Old Nov 18, 2001 | 08:43 PM
Scott's Avatar
With 28" tall tires and a 7000 rev limiter you'll be fine.
Scott
Old Nov 18, 2001 | 08:51 PM
Big Mike's Avatar
So I won't have to shift fifth? On spray though I won't be reving up to 7,000 rpms.
Old Nov 19, 2001 | 02:50 AM
Damian's Avatar
LSX Mechanic
As long as you run a decent size tire, and can SAFELY run it up to 7K on the nitrous you should be fine. Otherwise yes, you would have to shift into fifth.
Maybe some day Strange and Moser will wake up and make 3:90's for the 12 bolt's. THAT gear is great for n/a and nitrous cars.
Josh
Old Nov 19, 2001 | 08:42 AM
GeorgeC's Avatar
According to the gear/MPH calculator at www.f-body.org, with a 28" tire and 4.10 gears, 7000rpm would be 142mph... That's not accounting for tire growth (there will be some) or slippage (should be nil with a M6)... Even at only 6500, mph is still 132, so depending on how fast you think the car will go, 4.10's are probably a wise choice...
With my 4.33's, 28" tire, and 122mph trap speeds, I think my finish line rpms are around 6500 (I don't stare at the tach going through the traps).
Old Nov 19, 2001 | 08:56 AM
Big Mike's Avatar
George,
With spray though, I don't think I would want to take her up to 7,000. I don't do that now N/A. 7,000 is my rev limiter, I will actually be shifting at 6,400. How does that change the situation?
Old Nov 19, 2001 | 09:51 AM
69Muscle's Avatar
I knew you'd come over to the dark side mike! MUHAHAHAHAHAHAHAHAHA (Evil laugh)
Old Nov 19, 2001 | 09:56 AM
Big Mike's Avatar
Kyle, yup and dark it will be! New heads/cam setup with new shortblock and 100-150 shot will be the new setup. Surgery starts in January. 4.10's, 28" drag slick and looking into that 2-step that's been going around!
Old Nov 19, 2001 | 01:19 PM
Terry Burger's Avatar
Running juice and 4.10 gears is like eating pop rocks and drinking a coke. <img src="images/icons/wink.gif" border="0">
Old Nov 19, 2001 | 01:20 PM
ChrisB's Avatar
Big Mike: Check out http://www.f-body.org/gears/ for all your mph/gearing/rpm needs. With a 28" tire it sounds like 4.11's will be perfect.
Chris
Old Nov 19, 2001 | 02:21 PM
69Muscle's Avatar
When your ready to sell the CAM (What kind?) Drop me a line.
<img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
Old Nov 19, 2001 | 02:39 PM
Big Mike's Avatar
Terry, that's a good thing right?? <img src="images/icons/grin.gif" border="0"> <img src="images/icons/grin.gif" border="0">
Chris, I just checked it out. That is so cool, I never used the calculator before, thanks!!
Kyle, you got it bro! (B1)
[ November 19, 2001: Message edited by: Big Mike ]</p>
Old Nov 20, 2001 | 12:16 AM
69Muscle's Avatar
Damn I wished you lived closer, I'd love to see that work done. Are you doing it yourself? That damn 12.5 second timeslip I have just isn't good enough! <img src="images/icons/grin.gif" border="0">
What are you doing with your old heads/cam?
[ November 19, 2001: Message edited by: 69Muscle ]</p>
Old Nov 20, 2001 | 12:26 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
3.90's are available for 12 bolt rearends. Just not for stock rearends.
Big Mike, you will be fine, those slicks are tall.
[quote]Originally posted by DamianLS1:
<strong>As long as you run a decent size tire, and can SAFELY run it up to 7K on the nitrous you should be fine. Otherwise yes, you would have to shift into fifth.
Josh</strong><hr></blockquote>
Old Nov 20, 2001 | 12:28 AM
Big Mike's Avatar
I'm going to sell them when the time comes. Cartek will be doing the new work. I would love to go all MTI but its just not practical being they are 1,600 miles away. I know the Cartek guys well and trust them with my new setup!
Old Nov 20, 2001 | 12:29 AM
Big Mike's Avatar
Thanks PSJ!!!!!!
