Help Car wont start after Clutch install (long)
Everytime you even turn the key on, it blows the 20 fuse engine sensor. we put an A-tap on it on its throwing 2 codes. p-0108 and p-0803
skip shift. Well when I droped the trany I
missed those 2 wire conections on the back
of the trany. And ended up pulling the lower
one out of the wires. Wires came out of the plug.
The wires are one green, and one purple.
I tried to put them back into the plug but
nothing. Does anyone make a new plug I can connect
my wires into? Because I cant get them back in there tight. And can this be the problem?
Can just those 2 wires cause the car not to run?
All other connections are fine, My cars a 2000 Z
Thanks for any help.
Re: Help Car wont start after Clutch install (long)
I believe those wires are the cause of the problem...you could go to your dealer and order the sensor...but thats a pain...is there anyway that plug comes apart so you can place the wires back in???
I did a clutch install on my car with a friend...you got to be real careful when doing this type of stuff...
