ATI Super Damper - Looking for Info...
Is it a good mod (can you tell a difference is the supression of crank vibrations)?
Approximate price?
Best dealer for purchase?
Any other details?: Can you retain stock A/C? Etc..
I have a 383 and am looking to make the engine as smooth as possible. These bigger cams with the high flowing intakes tend to be less than "smooth" when flying through some of the RPM ranges...at least in my experience.
So, anyone have ANY information? I would really appreciate it. Thanks. <img src="images/icons/grin.gif" border="0">
http://www.atiperformanceproducts.com/
<img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Is it a good mod? Depends on how well balanced your engine is. It may prevent a little power lost to vibration over a standard underdrive pulley or it may do little or nothing if there is little vibration present to begin with. I was told this by ATI. They said they have ZERO dyno test results on an LS1 engine. Basically it can't hurt but it may not improve track times is what they said.
Price? About $340 I think.
Best dealer? I don't know but you could call ATI directly.
Yes you can retain the stock A/C, etc...
I don't think the cam would have anything to do with the dampener. It controls vibrations from the rotating assembly (crank, rods, pistons.)
[ November 23, 2001: Message edited by: Colonel ]
[ November 23, 2001: Message edited by: Colonel ]</p>
how well your engine is balanced(rotating assembly) makes no difference in how a Harmonic balancer works.
The Harmonic damper works on torsional vibrations that would destroy a crankshaft and bearings no matter how well it is balanced if it did not use one in very short time.
It is designed to cancel out the torsional or twisting vibrations created in the crank by the engines power pulses.
FYI, every ls1 Vortech kit comes with an ATI superdamper and I have one on my motor.They are are very nice pieces.
Nearly every Winston cup car uses an ATI super damper.
Steve
www.tech-ls1.com
Yes, Winston Cup uses them and they are FINE balancers, but that isn't to suggest that an LS1 will for sure pick up even 1 RWHP on the dyno with one nor fail to last 150,000 miles without one. That's the main point I was trying to get across of what ATI was telling me.
Again, I'm certainly not putting the ATI down...just passing along what they told me (more importantly, what they couldn't tell me.) I almost talked myself into buying one.
I'm just saying that I think my engine will last plenty long enough with my ASP pulley and that it'll make pretty much the same power. For those two reasons I'm not buying one until I can see some concrete evidence that my car would be faster with one.
So, IYO, would a perfectly balanced engine stand to gain just as much from an ATI balancer than a not-so perfectly balanced engine? Or might the imperfectly balanced engine stand to gain a little more?
Ryan
Again, it's not rotational balance but the odd firings of the cylinders.
When each cylinder fires the crank twists. A harmonic balancers job is to cancel out these twisting forces.
In severe cases a crank can actually break from these forces.
Yep high rpm and endurance motors need a better harmonic damper than say a strip motor that operates for a few seconds at a time.
Just think of it like anything else for your car.
You have good, better and best.
They are one of the best.
It came with my blower kit. Would I had shelled out the money for one if it had not come with the kit? probably not.
Steve
Give Thunder Racing a call. They are a dealer for ATI and have some in stock. They are not on the website yet, so call for pricing.
www.thunderracing.com
Jason
[ November 25, 2001: Message edited by: Jason99T/A ]</p>
btw, this is on my 475hp Speedvision GT Road-Race Corvette.
Dave
[ November 25, 2001: Message edited by: Dave F ]</p>
Dave
I just cut my own keyslot in the crank to accept a 3/16" wide 1" long Woodruff Key to lock the ATI superdamper to the crank as it was slipping with 10psi boost at 6500rpm.
They also now have some sort of drill fixture you can buy to fit dowel pins to pin it to the crank, which they recomend for circle track and supercharged use.
Gm goofed when they made a non keyed crank snout.
Steve
Angie
(Damn, I gotta watch what name I'm logged on under!)
[ November 26, 2001: Message edited by: Geoff ]</p>
